[OpenLayers-Users] Re: help with implementing controls on several
vector layers
Mr. Puneet Kishor
punk.kish at gmail.com
Sat Sep 24 22:28:24 EDT 2011
more info below --
On Sep 24, 2011, at 7:59 PM, Mr. Puneet Kishor wrote:
> I am not able to get select and highlight controls working for vector layers. I am using the following (pseudo)code and approach. Please help me identify the errors of my ways.
> Since I am adding several vector layers, each getting its own set of attributes, I have my simplified addLayer() method as below. Needless to say, the select, highlight and popup controls are not working. The layers draw correctly, and I get no javascript errors.
> var map;
> // repeat addLayer for several layers
> addLayer({url: url, name: name1, styleMap: styleMapObj});
> addLayer({url: url, name: name2, styleMap: styleMapObj});
> addLayer({url: url, name: name3, styleMap: styleMapObj});
> "onPopupClose" : function(evt) {
> if (this.feature.layer) {
> selectControl.unselect(this.feature);
> else {
> this.destroy();
> "addLayer" : function(a) {
> $.ajax({
> url: a.url + a.name + ".json",
> type: "GET",
> success: function(data) {
> var geojson_format = new OpenLayers.Format.GeoJSON();
> var lyr = new OpenLayers.Layer.Vector(a.name, {styleMap: a.styleMap});
> map.addLayer(lyr);
> lyr.addFeatures(geojson_format.read(data[a.name]));
> var highlightCtrl = new OpenLayers.Control.SelectFeature(lyr, {
> hover: true,
> highlightOnly: true,
> renderIntent: "temporary"
> var selectCtrl = new OpenLayers.Control.SelectFeature(lyr, {clickout: true});
> map.addControl(highlightCtrl);
> map.addControl(selectCtrl);
> highlightCtrl.activate();
> selectCtrl.activate();
> lyr.events.on({
> "featureselected": function(evt) {
> feature = evt.feature;
> var str = "";
> for (var i in feature.attributes) {
> str += "<b>" + i + ":</b> " + feature.attributes[i] + "<br />";
> popup = new OpenLayers.Popup.FramedCloud(
> "featurePopup",
> feature.geometry.getBounds().getCenterLonLat(),
> new OpenLayers.Size(300,250),
> str,
> null,
> true,
> onPopupClose
> feature.popup = popup;
> popup.feature = feature;
> map.addPopup(popup, true);
> "featureunselected": function(evt) {
> if (feature.popup) {
> popup.feature = null;
> map.removePopup(feature.popup);
> feature.popup.destroy();
> feature.popup = null;
So, reading more about SelectFeature, I can add multiple layers to it. So, I have moved my control creation code outside layer creation. Still, my problem may be that the layers are being created asynchronously, so I don't have an array of layers ready when I am creating the control. This creates a problem for me, unless there is a way around.
An additional issue -- once I have created a SelectFeature control, how do I add a new layer to it? The docs provide the control.setLayer method, but say that it would "Attach a new layer to the control, overriding any existing layers." Hmmmm... I don't want to destroy any existing layer. I want to add the new layer to the existing layers, so features on all the layers may be selectable/highlightable/popupWindowable.
Suggestions?
Thanks in advance.
