[OpenLayers-Users] Re: minifying geojson data
Puneet Kishor
punk.kish at gmail.com
Sun Sep 25 22:10:59 EDT 2011
On Sep 25, 2011, at 9:04 PM, Zac Spitzer wrote:
> simply enabling gzip/deflate compression works really well in
> reducing the transfer size for geoJSON... I often see a 10x win
> using the keymap is also a good approach and saves runtime
> memory in the browser
Yeah, will try out gzip when the need arises. For now, with keymap implemented, and with "pretty" JSON turned off (so I get more compact JSON), I cut the data being transferred to 1/3 (from about 1.8 MB to under 600 KB).
> On Mon, Sep 26, 2011 at 3:33 AM, Mr. Puneet Kishor <punk.kish at gmail.com>wrote:
>> solved... see below (might be of use to others)
>> On Sep 25, 2011, at 11:35 AM, Mr. Puneet Kishor wrote:
>>> Right now I am creating a vector layer with features that are clickable,
>> and show a popup window with the feature's attributes. My code is like so on
>> the server side where I am selecting (fictitious) "meetings" from a database
>>> while (meetings) {
>>> push @features, {
>>> type => "Feature",
>>> properties => {
>>> "long field1 name" => $field1,
>>> "long field2 name" => $field2,
>>> "long field3 name" => $field3
>>> geometry => {
>>> type => "Point",
>>> coordinates => [$lng, $lat]
>>> my %meetings = (
>>> meetings => {type => "FeatureCollection", features => \@features}
>>> my $res = to_json \%meetings;
>>> and then, in the browser
>>> // In my ajax call
>>> success: function(data) {
>>> var geojson_format = new OpenLayers.Format.GeoJSON();
>>> lyr.addFeatures(geojson_format.read(data["meetings"]));
>>> lyr.events.on({
>>> "featureselected": onFeatureSelect,
>>> "featureunselected": onFeatureUnselect
>> pass additional data to the `onFeatureSelect` callback like so
>> lyr.events.on({
>> "featureselected": function(evt) {
>> onFeatureSelect(evt, keymap);
>> and then, in the callback
>> // !onFeatureSelect(evt)
>> function onFeatureSelect(evt, keymap) {
>> feature = evt.feature;
>> var str = "";
>> for (var i in feature.attributes) {
>> str += "<b>" + keymap[i] + ":</b> " + feature.attributes[i]
>> + "<br />";
>> .. make popup window with str
>>> function onFeatureSelect(evt) {
>>> var feature = evt.feature;
>>> var str = "";
>>> str += "<b>" + i + ":</b> " + feature.attributes[i] + "<br
>>> popup = new OpenLayers.Popup.FramedCloud(.. using str ..);
>>> map.addPopup(popup, true);
>>> This works great, but for a few thousand features, all those "long fields
>> names" add up to a lot of wasteful data transfer. In the interest of
>> reducing data transfer, I am hoping to implement a keymap for my attribute
>> names (keys), and then send the keymap along with the new keys. Something
>> like so on the server side (kinda like my own minification scheme) --
>>> while (meetings) {
>>> push @features, {
>>> type => "Feature",
>>> properties => {
>>> a => $field1,
>>> b => $field2,
>>> c => $field3
>>> geometry => {
>>> type => "Point",
>>> my %meetings = (
>>> keymap => {
>>> a => "long field1 name",
>>> b => "long field2 name",
>>> c => "long field3 name"
>>> But, I am at a loss as to how to modify my JavaScript code to use this
>> keymap. `evt.feature` seems to have an "attributes" key that has been
>> automatically mapped to the "properties" key sent from the server. How do I
>> get the data.keymap to my onFeatureSelect(evt) callback?
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
