[OpenLayers-Users] How to use WCS with OpenLayers
Robert Buckley
robertdbuckley at yahoo.com
Wed Aug 15 02:39:51 PDT 2012
Thanks for your helpful reply.
I have been serving a DEM through wms....but was trying to try it with wcs...basically just as a learning excercise really.
The DEM works as the value = height..and so getFeatureInfo displays the attribute....but I was curious. If the wcs protocol is not available for web clients....which desktop clients use it? I don´t think QGIS has this capability.
yours,
Rob
Von: Jon Britton <jonbritton3 at gmail.com>
An: Robert Buckley <robertdbuckley at yahoo.com>
CC: "users at openlayers.org" <users at openlayers.org>
Gesendet: 11:34 Mittwoch, 15.August 2012
Betreff: Re: [OpenLayers-Users] How to use WCS with OpenLayers
Hi Robert,
You probably won't find any thin (browser) clients for displaying WCS data directly. There is such a sing as a Coverage Portrayal Service, which can make WCS data available through the WMS interface. However, GeoServer doesn't support it yet and as far as I know neither does anything else!
GeoServer makes coverages also available through WMS by default too. Couldn't you just display your data this way? Or do you need to access some of the more advanced functionality of WCS?
Jon
On 15 August 2012 10:12, Robert Buckley <robertdbuckley at yahoo.com> wrote:
Thanks.....that is all I wanted to know....that OpenLayers does not support wcs...but are there any api mapping libraries/thin clients or Hard clients (apart from ESRI) available?
>As I said....I am running the service through geoserver, but do not have a client to display it......and hence the question....are there any?
>Thanks,
>Robert
> Von: Bart van den Eijnden <bartvde at opengeo.org>
>Gesendet: 10:38 Mittwoch, 15.August 2012
>Not sure if I am getting what you're saying here.
>OpenLayers is a web mapping client, but has no support for WCS (currently).
>Best regards,
>Bart
>OpenGeo - http://opengeo.org
>Expert service straight from the developers.
>On Aug 15, 2012, at 10:31 AM, Robert Buckley <robertdbuckley at yahoo.com> wrote:
>ok....OpenLayers is not a client....but as a javascript mapping library one is able to program a thin-client for web-mapping purposes. And therefore, without splitting hairs, OpenLayers is the engine behind a thin-client based on OL...or am I wrong?
>>Gesendet: 9:53 Mittwoch, 15.August 2012
>>OpenLayers is not a WCS client.
>>Best regards,
>>Bart
>>On Aug 15, 2012, at 8:02 AM, Robert Buckley <robertdbuckley at yahoo.com> wrote:
>>Hi,
>>>I have been using wms to display and query a geotiff DEM from geoserver. The Height Field has been written into the geotiff on creation.
>>>I did this because at the time I didn´t know about wcs.
>>>If I wanted to serve the geotiff through the WCS protocol, how would I display and query it with OpenLayers? Has anyone doen this before and can share some experience?
>>>thanks,
>>>Robert_______________________________________________
>>>Users mailing list
>>>Users at lists.osgeo.org
>>>http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>Users mailing list
>Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120815/bee009b5/attachment-0001.html>
