03/12/2012 03:25 OpenGSC: > add event zoomstart on map, i suppose you mean movestart > if the mouse position does'n on your detail > area,return, "return false" prevents zooming in. > otherwise continue; Thanks for the hint. I tried and it works perfectly. Rainer
