[OpenLayers-Users] Updated Google Maps API and 3D
Andreas Hocevar
ahocevar at opengeo.org
Mon Dec 3 14:53:09 PST 2012
Hey Steven,
the purpose of adding camera and scene support to OpenLayers 3 is indeed
2.5D views for use cases like tilting and street views. The idea is to tilt
2D tiles and combine them with an elevation model or other height/elevation
information that is associated with the tiles. But we will also be working
on 3D vector rendering, in which case the 3D information is used directly
from the geometries, and all rendering is done on the client.
It seems the use case that you are envisioning is to request tilted tiles
from the server, i.e. to send requests for new tiles whenever the camera
properties change, which will then get rendered on the server and returned
to the client? Is this correct? If so, let's make sure it gets ticketed on
http://github.com/openlayers/ol3, so it won't be forgotten.
Andreas.
On Mon, Dec 3, 2012 at 10:36 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hi All,
> Sorry for the cross posting. The following article which is thin on
> details raise some interesting questions in my mind related to Mapserver
> and OpenLayers.
> http://www.zdnet.com/google-**dives-deeper-on-vector-based-**
> maps-with-api-update-**7000008233/?s_cid=e550<http://www.zdnet.com/google-dives-deeper-on-vector-based-maps-with-api-update-7000008233/?s_cid=e550>
> I know OpenLayers 3 is looking at potentially adding camera model to
> support tilted views. Would this be a static definition to support tiling?
> Or would the camera be able to be dynamically changed? This seems a lot
> like Google Street View.
> Has any thought been given to support for 2.5D or 3D features? Is there a
> need for this?
> If mapserver supported rendering orthogonal views or even a camera view
> model them a guess a layer could be defined to pass that information to
> mapserver to render in the same.
> Mapserver devs - there was some discussion about supporting 2.5D
> objections like buildings. In light of Google and Apple moving in these
> directions is this an area that we should be discussing for a future
> version. Should be be looking at a more flexible viewing model like a
> camera model as an option.
> It looks like the OGC is working on this also, google "ogc web 3d service".
> Seems like these questions should be discussed if they are not already
> being discussed.
> Thanks,
> -Steve
> ______________________________**_________________
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121203/cabd8f09/attachment-0001.html>
