[OpenLayers-Users] Load monitoring multiple layers
Jana Golinowski
jgolinowski at codematix.de
Tue Dec 4 00:27:39 PST 2012
Hello Manuel,
I think you'll have to monitor these layers yourself. I remember having problems
using the "moveend" event of the map (at least it didn't fit my needs).
But it's quite simple to catch that "all layers are loaded" event. Just declare
a global (or semi-global) counter, increase it on each "loadstart" and decrease
it on each "loadend". When the counter is back to zero you're done.
Applied to your sample code:
var layerCounter = 0;
function registerEvents(layer) {
layer.events.register("loadstart", layer, function() {
layerCounter++;
layer.events.register("loadend", layer, function() {
layerCounter--;
if (layerCounter == 0) {
// now all layers should be loaded
Greeting, Jana.
Am 04.12.2012 22:09, schrieb Manuel Arredondo:
> I have multiple WMS layers on an OpenStreetMap base layer. I want to be able to
> know when there are no more map requests being done by any layer. I have used
> the OL example to monitor layers as shown below.
> Do I have to monitor each layer separately and give them a boolean to switch to
> true when their ‘loadend’ event is triggered?
> or is there an API call I can use which monitors all the events as a whole?
> The map event doesn’t have a “loadend” event type.
> this.logEvent("Ready");
> baseTilesLoaded = true;
> map.addLayer(layer);
> Best Regards,
> Manuel Arredondo.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
