[OpenLayers-Users] Show and hide maps with a button in OpenLayers
pascal evano
pascal2833 at gmail.com
Thu Dec 6 01:43:11 PST 2012
Hi!
The problem is that if I try to hide and remove the id after using the
function createmap, the firebug writes: "b is null". It seems that the fact
of removing or hiding the id works but then it's impossible to show or
recreate the map and all these elements.
So, what can I do to integrate all the elements which are in the map?
Pascal.
2012/12/5 OpenGSC <945070223 at qq.com>
> I think you only remove div ,but doesn't remove map
> you ought to add some sentence in createmap1 function to judge whether map
> has been created,if it was,show,if not create map
> I am OGCer V1.0 owner!
> http://osgeo-org.1560.n6.nabble.com/Show-and-hide-maps-with-a-button-in-OpenLayers-tp5020705p5020808.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121206/5bfbb3b6/attachment.html>
