[OpenLayers-Users] zooming to fit the full earth using google maps layers
Jeff Storey
jeff.storey at nextcentury.com
Thu Dec 6 16:53:06 PST 2012
I have a map that uses the google earth hybrid layer as the base layer. I would like it so the map is initially zoomed to show the whole world, but I can't quite figure out how.
My code looks like
var map = new OpenLayers.Map({
div: "map",
projection: 'EPSG:3857',
layers: [
new OpenLayers.Layer.Google("Google Hybrid",{type: google.maps.MapTypeId.HYBRID, numZoomLevels: 20})
center: new OpenLayers.LonLat(0,0).transform('EPSG:4326', 'EPSG:3857')
map.zoomToMapExtent();
Do I need to set the map div dimensions to a particular aspect ratio (or a minimum height/width)?
Also, is there a way to prevent the user from panning when zoomed out all the way?
Thanks,
Jeff
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121206/04b1d121/attachment.html>
