[OpenLayers-Users] SelectFeature unselecting programmatically
Andreas Hocevar
ahocevar at opengeo.org
Mon Dec 10 00:56:06 PST 2012
Would you mind creating a pull request for this? It is easier to
discuss things like this over code that can be seen in context an
executed.
Thanks,
Andreas.
On Fri, Dec 7, 2012 at 1:24 PM, Slawomir Messner
<slawomir.messner at staff.uni-marburg.de> wrote:
> Hi,
> when you use select/unselect function of SelectFeature control why
> this.handlers.feature.lastFeature is set in select function but not in unset
> in unselect? It's not just the asymmetry which bother me, it is also that it
> would solve an issue in the following scenario:
> We have a RemoveFeature control which can also remove vertices of polygons
> and lines.
> We use a SelectFeature to select a feature. On select it draws edit vertices
> on the edges, like the ModifyFeature control and a Feature handler handles
> the click on the vertices and removes it form layer and the geometry. After
> removing it redraws the feature and all seams well, the feature is correctly
> drawn, the vertex is gone and it's selected but unfortunately clickout
> doesn't work(it works when you select and clickout without deleting vertex).
> After some investigation I found out that lastFeature of the feature handler
> in SelectFeature control is the deleted vertex. So on click outside the
> feature the handler runs handle method where it sets lastFeature to null,
> because it is removed from layer.
> if(this.lastFeature && !this.lastFeature.layer) {
> // last feature has been destroyed
> this.lastFeature = null;
> so it never gets some lines below:
> } else {
> if(this.lastFeature && (previouslyIn || click)) {
> this.triggerCallback(type, 'out', [this.lastFeature]);
> there it should call the clickout callback. So I tried it with unselect and
> than select the feature programmatically after deleting the vertex, to reset
> the select, but this didn't help. The only thing that helps is when I set
> the lastFeature to null before reselect or to set it to the feature without
> . Why not "simple" do something like:
> "this.selectFeature.handlers.feature.lastFeature = this.feature"
> because it looks ugly, uses some attributes which should be private and I
> saw the asymmetry in the code of the SelectFeature and asked myself if it's
> a bug or a feature.
> Is there something why not change the unselect method of SelectFeature to:
> unselect: function(feature) {
> var layer = feature.layer;
> // Store feature style for restoration later
> this.unhighlight(feature);
> // if the feature handler isn't involved in the feature
> // selection (because the feature is selected programatically)
> // we fake the
> // feature handler to allow unselecting on clickout
> if(this.handlers.feature.lastFeature) {
> this.handlers.feature.lastFeature = null;
> OpenLayers.Util.removeItem(layer.selectedFeatures, feature);
> layer.events.triggerEvent("featureunselected", {feature: feature});
> this.onUnselect.call(this.scope, feature);
> It doesn't crash the tests.
> Btw:
> I think there is a documentation error in OL.Handler.Feauture deactivate
> function it should be:
> * Method: deactivate
> * Turn off the handler. Returns false if the handler was not active.
> * Returns:
> * {Boolean}
> Keep up the excellent work guys, we look forward to OL3.
> Regards
> Slawomir
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
