[OpenLayers-Users] problem with open up popup with WMSGetFeatureInfo control
Andreas Hocevar
ahocevar at opengeo.org
Mon Dec 10 00:59:57 PST 2012
When using the text/html format, you do not need the default format
(OpenLayers.Format.WMSGetFeatureInfo) to parse your features. So when
configuring your OpenLayers.Control.WMSGetFeatureInfo, set the
following format:
format: {read: function(doc) {return doc; }}
Andreas.
On Fri, Dec 7, 2012 at 5:11 PM, Karina Guardado <kguardado at gmail.com> wrote:
> Hi everybody,
> I'm using the WMSGetFeatureInfo control with openlayers 2.11 and mapfish,
> mapserver, linux Debian. When I click on a point I get the popup with the
> information but can not close the popup. I have tried with a few layers and
> there is no problem but when using more then it is not possible to close the
> popup box. I have review the layers and are ok so I think the problem is
> with the control WMSGetFeatureInfo.
> Is there a limit of layers I can use with this control? or is a problem with
> the apache or something else?
> Here is the code I'm using.
> Thanks in advance. Regards.
> toolbar.addControl(new OpenLayers.Control.WMSGetFeatureInfo({
> url:
> 'http://200.13.186.56/cgi-bin/mapserv?MAP=/var/www/geo/pages/client/opamssmapfile.map&',
> title: 'Identify features by clicking',
> queryVisible: true,
> infoFormat:'text/html',
> click: 'true',
> layers: [infecos, infcasasalud, infalbergues,
> infcentronutre, infhospitales, infsibasis, infhogarespera, infpromotor,
> AgisECOS, Municipios, MuniMesoamerica, infecosmesoamerica, proyconstruccion,
> proyequipamiento, proyconstruccionAvance, proyequipamientoAvance,
> ProyConstruccionPrides, ProyequipamientoPrides,
> ProyConstruccionAvancePrides, ProyequipamientoAvancePrides, RegionOriental,
> RegionParacentral, RegionCentral, RegionOccidental,
> RegionMetropolitana,MicroredAtiquizaya, MicroredCaraSucia,
> MicroredGuaymango, MicroredJujutla,
> MicroredAtiquizayaMuni,MicroredAhuachapanMuni, MicroredCaraSuciaMuni,
> MicroredGuaymangoMuni, MicroredJujutlaMuni,infecosAtiquizaya,
> infhospitalesAtiquizaya, infecosAhuachapan, infhospitalesAhuachapan,
> infecosCaraSucia, infhospitalesCaraSucia, infecosGuaymango,
> infhospitalesGuaymango, infecosJujutla, infhospitalesJujutla,
> MicroredSonsonate, MicroredSonzacate, MicroredAcajutla, MicroredIzalco,
> MicroredLourdesColon, MicroredSonsonateMuni, infecosSonsonate,
> infhospitalesSonsonate, MicroredSonzacateMuni, infecosSonzacate,
> infhospitalesSonzacate,MicroredAcajutlaMuni, infecosAcajutla,
> infhospitalesAcajutla, MicroredIzalcoMuni, infecosIzalco,
> infhospitalesIzalco,MicroredLourdesColonMuni, infecosLourdesColon,
> infhospitalesLourdesColon, MicroredMetapan, MicroredTexistepeque,
> MicroredElcongo, MicroredTomasPineda, MicroredChalchuapa,
> MicroredMetapanMuni, infecosMetapan, infhospitalesMetapan,
> MicroredTexistepequeMuni, infecosTexistepeque, infhospitalesTexistepeque,
> MicroredElcongoMuni, infecosElcongo, infhospitalesElcongo,
> MicroredTomasPinedaMuni, infecosTomasPineda, infhospitalesTomasPineda,
> MicroredChalchuapaMuni, infecosChalchuapa, infhospitalesChalchuapa,
> MicroredPerquin, MicroredOsicala, MicroredSanFranciscoGotera,
> MicroredSensembra, MicroredPerquinMuni, infecosPerquin,
> infhospitalesPerquin, MicroredOsicalaMuni, infecosOsicala,
> infhospitalesOsicala, MicroredSanFranciscoGoteraMuni,
> infecosSanFranciscoGotera, infhospitalesSanFranciscoGotera,
> MicroredSensembraMuni, infecosSensembra, infhospitalesSensembra],
> eventListeners: {
> getfeatureinfo: function(event) {
> map.addPopup(new OpenLayers.Popup.FramedCloud(
> \"chicken\",
> map.getLonLatFromPixel(event.xy),
> null,
> event.text,
> null,
> true
> isDefault: true,
> title: 'Info'
> iconCls: 'query',
> toggleGroup: 'map'
> Karina Guardado
> El Salvador
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
