[OpenLayers-Users] vector doesn't display
Matt Priour
mpriour at kestrelcomputer.com
Wed Dec 12 10:11:01 PST 2012
You have to actually load the GeoJSON features into the layer.
First, look at the following examples:
http://openlayers.org/dev/examples/geojson-reprojected.html
http://openlayers.org/dev/examples/cartodb-geojson.html
They both use a Fixed strategy which is the best one if you want to load
your data once and have it in a static file or known URL.
You would add your style definition to the vector layer definition they
present in these examples and then you would have a layer with features
to be symbolized.
Matt Priour
Kestrel Computer Consulting
On 12/12/2012 6:21 AM, Gery . wrote:
> Hello,
> I have some features in GeoJSON format I want to display, so I did this:
> [code]
> var vectorLayer = null;
> var vectorStyle =
> graphicName: 'square',
> strokeColor: '#222',
> fillColor: '#222'
> var styleDefault = OpenLayers.Util.applyDefaults(
> vectorStyle,
> OpenLayers.Feature.Vector.style['default']
> vectorLayer = new OpenLayers.Layer.Vector('search',
> styleMap: new OpenLayers.StyleMap(
> 'default': styleDefault
> displayInLayerSwitcher: true
> [/code]
> but they don't appear in the map, my question is if this is enough to
> get the features displayed or do I need something else there? if this
> is enough, I should think that this problem is about how the features
> are being read by OL. In fact, this doesn't work either:
> var ll = new OpenLayers.LonLat(feature.geometry.x, feature.geometry.y);
> mapPanel.map.setCenter(ll);
> I get:
> feature is not defined
> [Break On This Error]
> why should this happen? thanks in advance
> __________________________________________________________________________________________
> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas
> si NO es necesario.
> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
> Denken Sie an die Umwelt- bewahren Sie es auf dem Bildschirm. Drucken
> Sie NICHT, wenn es NICHT notwendig ist.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121212/30e3d3ae/attachment.html>
