[OpenLayers-Users] OpenLS Geocode Not Working
Matt Priour
mpriour at kestrelcomputer.com
Wed Dec 12 11:59:55 PST 2012
The answer is highly dependant on what server setup you have.
Are you hosting / proxing Apache through IIS? - then just put proxy.cgi
in a scriptAlias directory
Do you have IIS handlers configured to run Python files? - rename
proxy.cgi to proxy.py and put it here it can be accessed and run
If no to the above questions, then you should look at the ArcGIS for
Javascript Proxy Page help
http://resources.esri.com/help/9.3/arcgisserver/apis/javascript/arcgis/help/jshelp_start.htm#jshelp/ags_proxy.htm
The intro and section 1 are relevant.
Finally, set OpenLayers.ProxyHost to point to the correct location of
your proxy. Make sure that your proxy and your webpage with the
OpenLayers map are on the same subdomain, host, and port.
Hope that helps
Matt Priour
On 12/12/2012 12:57 PM, BrianJBaldwin wrote:
> Thanks so much for the responses.
> It looks like the issue is coming down to getting the proxy.cgi working with
> IIS.
> How do I rename this file and where do I place it in this circumstance?
> I have found a few different resources for doing this, but everything looks
> fairly convoluted.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/OpenLS-Geocode-Not-Working-tp5022525p5022571.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
