[OpenLayers-Users] Ruled-Based Styling Does Not Work with KML File
Matt Priour mpriour at kestrelcomputer.com
Fri Dec 14 09:17:24 PST 2012
Since you are using a KML file with attributes in the ExtendedData
section, you need to tell the KML parser to use a simple attribute
key:value model if you want to write rule based styling without an
additional conversion function.
new OpenLayers.Format.KML({
                extractStyles: false,
                extractAttributes: true,
                kvpAttribures: true, // <- THAT is the important part
you are missing
                srsName: "EPSG:900913"
Matt Priour
On 12/14/2012 6:53 AM, reinaldo at geodesign.com.br wrote:
> OL Users,
> I can't get the rule-base styling to work on a KML file.
> Please find below my JS, HTML and KML files.
> I would appreciate very much if someone could help me.
> I examined the examples, read the documentation and double checked the
> KML file structure. Evertyhing indicate that the rule-based styling
> should work, but it doesn't.
> I created a simple kml file with one attribute for each placemark. I
> can get the attributes rendered as labels, but I can not do the
> rule-based styling to work It looks like the rules are not being
> evaluated because I only get the elseifFilter style result rendered.
> It does not evaluate the other two EQUAL_TO rules, or any other
> Filter.Comparison rule.
> Thanks in advance,
> Reinaldo
> *** JS FILE **************************************
> var map = new OpenLayers.Map("map");
> var vector_style = new OpenLayers.Style(
>         fillColor: "#00ff00",
>         fillOpacity: 0.1,
>         strokeWidth: 1,
>         strokeColor: "#0000ff",
>         strokeOpacity: 4,
> //        label: '${state}',
> //        fontColor: "#ff0000",
> //        fontFamily: "sans-serif",
> //        fontSize: "10px",
> //        fontWeight: "bold"
> //context: {
> //state: function(feature){ return feature.attributes.SUMMER.value; }
>    rules: [
>      new OpenLayers.Rule({
>             filter: new OpenLayers.Filter.Comparison({
>             type: OpenLayers.Filter.Comparison.EQUAL_TO,
>             property: "SUMMER",
>             value: 1000.123
>             symbolizer: {
>            fillColor: "#ff0000",
>            fillOpacity: 1.0,
>            strokeWidth: 1,
>            strokeColor: "#ff0000",
>            strokeOpacity: 4,
>             property: "SUMMER",
>             value: 2000.123
>             symbolizer: {
>            fillOpacity: 1.0,
>            strokeWidth: 1,
>            strokeColor: "#00ff00",
>            strokeOpacity: 4,
>          // apply this rule if no others apply
>             elseFilter: true,
>             symbolizer: {
>                fillColor: "#ffff00",
>                fillOpacity: 1.0,
>                strokeWidth: 1,
>                strokeColor: "#ffffff",
>                strokeOpacity: 4,
> var vector_style_map = new OpenLayers.StyleMap({
> 'default': vector_style
> var vectorlayer = new OpenLayers.Layer.Vector("SOLAR RAD BAHIA", {
>         strategies: [new OpenLayers.Strategy.Fixed()],
>         protocol: new OpenLayers.Protocol.HTTP({
>            url: "kml/ba_diff_simple1.kml",
>             format: new OpenLayers.Format.KML({
>         styleMap: vector_style_map
> var googleLayer = new OpenLayers.Layer.Google("Google Satellite",
>             {type: google.maps.MapTypeId.SATELLITE, numZoomLevels: 22}
> map.addLayers([googleLayer, vectorlayer]);
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.zoomToMaxExtent();
> *** HTML FILE **************************************
> <!DOCTYPE html>
> <html>
> <html>
>     <head>
>     <meta http-equiv="Content-Type" content="text/html; ">
>     <meta name="viewport" content="width=device-width,
> initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
>     <meta name="apple-mobile-web-app-capable" content="yes">
>         <link rel="stylesheet" href="../theme/default/style.css"
> type="text/css">
>         <link rel="stylesheet" href="style.css" type="text/css">
>         <script
> src="http://maps.google.com/maps/api/js?v=3&sensor=false"></script>
> <style type="text/css">
> #map {
>     width: 600px;
>     height: 450px;
>     border: 1px solid black;
> </style>
>     </head>
>     <body>
>         <h1 id="title">OpenLayers Example</h1>
>         <div id="tags">simple, basic, light</div>
>         <div id="map" class="smallmap"></div>
>         <script src="../lib/OpenLayers.js"></script>
>         <script src="example1.js"></script>
>     </body>
> </html>
> *** KML FILE **************************************
> <kml xmlns="http://www.opengis.net/kml/2.2">
>   <Document>
>     <Folder>
>       <name>diffuse_summer</name>
>       <Schema name="ba_diffuse_summer" id="ba_summerId">
>     <SimpleField name="SUMMER" type="double"></SimpleField>
>       </Schema>
>       <Placemark>
>         <Style>
>           <LineStyle>
>             <color>ff0000ff</color>
>           </LineStyle>
>           <PolyStyle>
>             <fill>0</fill>
>           </PolyStyle>
>         </Style>
>         <ExtendedData>
>           <SchemaData schemaUrl="#ba_summerId">
>             <SimpleData name="SUMMER">1000.123</SimpleData>
>           </SchemaData>
>         </ExtendedData>
>         <Polygon>
>           <outerBoundaryIs>
>             <LinearRing>
> <coordinates>-39.551991120000018,-8.654038020000009
> -39.461196960000017,-8.650702980000011
> -39.457748160000023,-8.738279009999998
> -39.54856104000001,-8.741648970000023
> -39.551991120000018,-8.654038020000009</coordinates>
>             </LinearRing>
>           </outerBoundaryIs>
>         </Polygon>
>       </Placemark>
>       <Placemark>
>         <Style>
>           <LineStyle>
>           </LineStyle>
>           <PolyStyle>
>             <fill>0</fill>
>           </PolyStyle>
>         </Style>
>         <ExtendedData>
>             <SimpleData name="SUMMER">2000.123</SimpleData>
>           </SchemaData>
>         </ExtendedData>
>         <Polygon>
>           <outerBoundaryIs>
>             <LinearRing>
> <coordinates>-39.370407120000024,-8.647350030000021
> -39.27961296000003,-8.643977999999999
> -39.27612708000003,-8.731485000000008
> -39.366936000000003,-8.734890960000024
> -39.370407120000024,-8.647350030000021</coordinates>
>             </LinearRing>
>           </outerBoundaryIs>
>         </Polygon>
>       </Placemark>
>       <Placemark>
>         <Style>
>           <LineStyle>
>           </LineStyle>
>           <PolyStyle>
>             <fill>0</fill>
>           </PolyStyle>
>         </Style>
>         <ExtendedData>
>           <SchemaData schemaUrl="#ba_diffuse_summerId">
>             <SimpleData name="SUMMER">3000.123</SimpleData>
>           </SchemaData>
>         </ExtendedData>
>         <Polygon>
>           <outerBoundaryIs>
>             <LinearRing>
> <coordinates>-41.365158120000011,-8.805078990000009
> -41.274315,-8.802090000000005 -41.271233040000013,-8.890313040000013
> -41.362098840000023,-8.893332990000021
> -41.365158120000011,-8.805078990000009</coordinates>
>             </LinearRing>
>           </outerBoundaryIs>
>         </Polygon>
>       </Placemark>
>     </Folder>
>   </Document>
> </kml>
> Reinaldo Escada Chohfi
> Sócio Gerente
> GeoDesign Internacional
> www.geodesign.com.br <http://www.geodesign.com.br>
> Tel./Fax: (12) 3153-5115
> Inteligência e Tecnologia Espacial de Ponta
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121214/4b8dd7d1/attachment.html>
