[OpenLayers-Users] Pass an XY coordinate to my marker
BrianJBaldwin
BrianJBaldwin at gmail.com
Fri Dec 14 13:14:54 PST 2012
I think this is a pretty simply problem, I just don't have the JS knowledge
to get it solved.
This is the output from the address locator, where it pulls the XY of the
address. I was to pass the geometry.x and geometry.y to my marker.
Here is the code from the address locator:
function requestSuccess(response) {
var format = new OpenLayers.Format.XLS();
var output = format.read(response.responseXML);
if (output.responseLists[0]) {
var geometry = output.responseLists[0].features[0].geometry;
var foundPosition = new OpenLayers.LonLat(geometry.x,
geometry.y).transform(
new OpenLayers.Projection("EPSG:4326"),
map.getProjectionObject()
map.setCenter(foundPosition, 16);
Here is my marker location, can I just pass the new geometry to this point?
If so, what is the best way to do this?
var myLocation = new OpenLayers.Geometry.Point()
.transform('EPSG:4326', 'EPSG:3857');
View this message in context: http://osgeo-org.1560.n6.nabble.com/Pass-an-XY-coordinate-to-my-marker-tp5023145.html
