[OpenLayers-Users] OpenLayers.Layer.WMS - using SVG Format?
Harris Hudson
hhudson at katmandu.org
Fri Dec 14 22:37:47 PST 2012
Using OpenLayers.Layer.WMS to add a WMS SVG (image/svg+xml) format layer
should work fine for modern browsers. I've successfully added WMS SVG
layers using OpenLayers.Layer.WMS where the layer tiles are added to the
map based either on the <img> tag or the <iframe> tag. You might just need
to have <!DOCTYPE html> at the top of your page for versions of IE that
support SVG.
In non standard cases where your WMS produces a non-static or an interactive
SVG layer, or an SVG layer that has external styling for example, then you
might consider trying OpenLayers.Layer.WMS.InlineXhtml from the InlineXhtml
Addin.
Regards,
Harris.
> Hi, just wondering if instead of pushing out an OpenLayers.Layer.WMS as
> format:image/png I can use svg. My getcapabilities request of my WMS says
> that is supports SVG with the following -
> - <GetMap>
> <Format>image/png</Format>
> <Format>image/jpeg</Format>
> <Format>image/svg+xml</Format>
> <Format>svgz</Format>
> However when I declare a WMS layer with svg format it does not show, is
> there any way to use SVG with a WMS layer? Thanks.
> layer_Overview = new OpenLayers.Layer.WMS("Overview Map Layers", wms, {
> layers: ["OVERVIEW_County", "OVERVIEW_City_Boundaries",
> "OVERVIEW_Roads", "OVERVIEW_River", "OVERVIEW_Roads_Highways"],
> VERSION: "1.3.0",
> format: 'image/svg+xml'
> isBaseLayer: true,
> displayInLayerSwitcher: false,
> singleTile: true,
> buffer: 1,
> ratio: 1
> http://osgeo-org.1560.n6.nabble.com/OpenLayers-Layer-WMS-using-SVG-Format-tp5023159.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
