Hello Matt thank you for the explanation, it was of great help! Basically I want to list POIS on a map, not only from OpenMarkers. Meanwhile I also found this wiki entry which points in the right direction: http://wiki.openstreetmap.org/wiki/OpenLayers_Dynamic_POI Cheers gerhard
