[OpenLayers-Users] Simple KML layer help
Arnd Wippermann
arnd.wippermann at web.de
Wed Dec 19 07:19:53 PST 2012
Instead in- and externalProjection you can use projection in the layer
options.
var l = new OpenLayers.Layer.Vector("KML", {
strategies: [new OpenLayers.Strategy.Fixed()],
projection: new OpenLayers.Projection("EPSG:4326"), //projection of the
data
protocol: new OpenLayers.Protocol.HTTP({
url: "test.kml",
format: new OpenLayers.Format.KML({
extractStyles: true,
extractAttributes: true,
maxDepth: 2
-----Ursprüngliche Nachricht-----
Von: Bill Schoolfield [mailto:bill at billmax.com]
Gesendet: Mittwoch, 19. Dezember 2012 00:46
An: arnd.wippermann at web.de
Betreff: Re: AW: [OpenLayers-Users] Simple KML layer help
Arnd,
Thanks. I made your change and it works. Gesh, Looked at that forever.
Is the code correct otherwise? Seems like I may have done unnecessary things
while trying to sort this out.
Bill
On 12/18/2012 5:29 PM, Arnd Wippermann wrote:
> The Coordinate is lon, lat
> <coordinates>-96.80933013, 32.77874075, 0.</coordinates> Elm St in Dallas?
> With your coordinates lat is -96 and thats outside projection.
> Arnd
> Von: openlayers-users-bounces at lists.osgeo.org
> [mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Bill
> Schoolfield
> Gesendet: Dienstag, 18. Dezember 2012 22:45
> An: openlayers-users at lists.osgeo.org
> Betreff: [OpenLayers-Users] Simple KML layer help
> Sorry for the last post: Here is my request in its entirety:
> I'm trying to add a simple KML layer to a OL Map. I assume I have to
> worry about projection of the lat/longs in the KML file. The following
> runs w/o error but I don't see my KML layer. The rest of the map is
> fine. I know this is very close to other posts and topics but I can't
> quite seem to get anything to work.
> Here is the php file that takes lat long arguments and produces a map:
> <html><body>
> <div id="map"></div>
> <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
> <script>
> map = new OpenLayers.Map("map");
> map.addLayer(new OpenLayers.Layer.OSM("map"));
> url: "test.kml",
> maxDepth: 2,
> 'internalProjection': new
> OpenLayers.Projection("EPSG:900913"),
> 'externalProjection': new
> map.addLayer(l);
> map.addControl(
> new OpenLayers.Control.MousePosition({
> prefix: '<a target="_blank" ' +
> 'href="http://spatialreference.org/ref/epsg/4326/">' +
> 'EPSG:4326</a> coordinates: ',
> separator: ' | ',
> numDigits: 2,
> emptyString: 'Mouse is not over map.'
> var proj = new OpenLayers.Projection("EPSG:4326");
> var point = new OpenLayers.LonLat(<?php echo $_GET["long"];
> ?> , <?php echo $_GET["lat"]; ?>);
> point.transform(proj, map.getProjectionObject());
> map.setCenter(point, 13);
> </script>
> </body></html>
> And here is the test.kml file:
> <?xml version="1.0" encoding="UTF-8"?> <kml
> xmlns="http://www.opengis.net/kml/2.2">
> <Document>
> <Placemark>
> <name>MY POINT</name>
> <description>My Point</description>
> <Point>
> <coordinates>32.77874075,-96.80933013, 0.</coordinates>
> <Icon>
<href>http://maps.google.com/mapfiles/kml/shapes/sunny.png</href>
> </Icon>
> </Point>
> </Placemark>
> </Document>
> </kml>
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
