[OpenLayers-Users] How do I get my polygon coordinates?
Imran Rajjad rajjad at gmail.com
Tue Feb 7 07:38:24 EST 2012
if you insert the circle into a vector layer , you should be able to get
the coordinates of its geometry through the thwo lines I wrote in my
response earlier.
regards,
Imran
On Tue, Feb 7, 2012 at 5:20 PM, Blake <blakeloizides at gmail.com> wrote:
> I have created a map with create circle now after you draw the circle I
> want the
> coordinates of the circle.
> Please help?
> <html xmlns="http://www.w3.org/1999/xhtml">
>  <head>
>   <style type="text/css">
>  html, body, #map {
>                margin: 0;
>                width: 100%;
>                height: 100%;
>     </style>
>        #controls {
>            width: 512px;
>                        position: absolute;
>            bottom: 1em;
>            left: 1em;
>            width: 300px;
>            z-index: 20000;
>            background-color: #8194D5;
>            padding: 0 0.5em 0.5em 0.5em;
>        #controlToggle {
>            padding-left: 1em;
>        #controlToggle li {
>            list-style: none;
>    </style>
> <link rel="stylesheet" href="theme/default/style.css" type="text/css">
> <link href="css/style.css" rel="stylesheet" type="text/css" />
> <script src="js/firebug.js"></script>
> <script src="http://www.openlayers.org/dev/OpenLayers.js"></script>
> <script type="text/javascript">
>        var lon = 24.0000000000;
>        var lat = -29.000000000000;
>        var zoom = 4;
>        var map, layer, vectors, controls;
>        function init(){
>           // Because the Streetmaps system uses 300x300 tiles, we need to
> set
> up the scaling variables to work with these
> var aRes =
> [90,45,22.500000,11.250000,
> 5.625000,2.812500,1.406250,0.703125,
> 0.351563,0.175781,0.087891,0.043945,0.021973,0.010986,
> 0.005493,0.002747,0.001373,0.000687,0.000343];
>         for (var l=0;l<aRes.length;l++) { aRes[l] = aRes[l]/300; }
>          // Normal init, but we pass through the info about the
> zoom/scaling as
> options
>          map = new OpenLayers.Map( 'map', { tileSize:
> new OpenLayers.Size(300,
> 300), projection: 'CRS:84',
> numZoomLevels:aRes.length, resolutions:aRes,
> maxResolution:360/300 } );
>          // At this point the control is used as per normal
>            layer1 = new OpenLayers.Layer.WMS(
>                              'Streetmaps Streets',
>                              'http://www.streetmaps.co.za/WMS/?',
>                              key:
> 'HZPGNWPNDYPREPTIKSIHWKYKQYYOQVYX',
>                              service:                                'WMS',
>                              request:
>  'GetMap',
>                              version:
>  '1.3.0',
>                              layers:
> 'sm.maps.tiled',
>                              format:
> 'image/png'
>            layer2 = new OpenLayers.Layer.WMS(
>                              'Streetmaps Imagery',
>                              key:
>                              service:                                'WMS',
>                              request:
>  'GetMap',
>                              version:
>  '1.3.0',
>                              layers:
> 'sm.imagery',
>                              format:
> 'image/png'
> // This loads the overlays
>            map.addLayer(layer1);
>            map.addLayer(layer2);
>            map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
>            map.addControl( new OpenLayers.Control.LayerSwitcher() );
>                        var vectors = new OpenLayers.Layer.Vector("vector",
> {isBaseLayer: true});
>                        map.addControl(new
> OpenLayers.Control.EditingToolbar(vectors));
>                        map.addControl(new
> OpenLayers.Control.MousePosition());
>  var wmsLayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>                "http://vmap0.tiles.osgeo.org/wms/vmap0?", {layers:
> 'basic'});
>            var polygonLayer = new OpenLayers.Layer.Vector("Polygon Layer");
>            map.addLayers([wmsLayer, polygonLayer]);
>            polyOptions = {sides: 40};
>            polygonControl = new
> OpenLayers.Control.DrawFeature(polygonLayer,
>  OpenLayers.Handler.RegularPolygon,
>                                            {handlerOptions: polyOptions});
>            map.addControl(polygonControl);
>            document.getElementById('noneToggle').checked = true;
>             document.getElementById('irregularToggle').checked = false;
>        function toggleControl(element) {
>            for(key in controls) {
>                var control = controls[key];
>                if(element.value == key && element.checked) {
>                    control.activate();
>                } else {
>                    control.deactivate();
>    </script>
>  </head>
>  <body onLoad="init()">
>    <div id="map" class="smallmap"></div>
>    <div id="controls">
>        <ul id="controlToggle">
>             <li>
>                <input type="radio" name="type"
>                       value="none" id="noneToggle"
>                       onclick="polygonControl.deactivate()"
>                       checked="checked" />
>                <label for="noneToggle">navigate</label>
>            </li>
>            <li>
>                       value="polygon" id="polygonToggle"
>                       onclick="polygonControl.activate()" />
>                <label for="polygonToggle">draw polygon</label>
>            </li>
>        </ul>
>    </div>
>  </body>
> </html>
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
I.R
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120207/3a112066/attachment.html
