[OpenLayers-Users] Re: SelectFeature when using IE<9 or IE9
Compatibility View
digitalfox
andreas at digitalfox.se
Thu Feb 9 08:42:07 EST 2012
*Solution found!*
After basically two days of constant debugging by removing and adding
functionality piece by piece, I've figured out what caused the problem.
As I've stated earlier, we create a StypeMap based on the default styles of
the Vector-layer and extended with our custom values. While debugging, I
noticed that if the StyleMap used only the default styles of the
Vector-layer, the SelectFeature-control would function in all versions of
Internet Explorer. But if we added our custom styles, the
SelectFeature-control would fail. So why was this?
The style-property that was causing the problem was the *rotation*-property.
We added this to the styles with a value of '0', i.e. no rotation as the
default value for the property. However, this caused our features to not be
selectable when using Internenet Explorer versions older than 9 (verified
using IE9 CV, IE8, IE7). Everything works great in FireFox and Chrome
though!
Simply removing the property from the styles solved the problem!
View this message in context: http://osgeo-org.1560.n6.nabble.com/SelectFeature-when-using-IE-9-or-IE9-Compatibility-View-tp4368621p4379406.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120209/a4242f61/attachment.html
