[OpenLayers-Users] Hassles trying to run with closure compiler.
Phil Scadden
p.scadden at gns.cri.nz
Thu Feb 9 18:24:40 EST 2012
>I was having same problem so I did:
> build.py -c none myconfig.cfg uncompressed.js
> java compiler.jar --js uncompressed.js --OpenLayers-closure.js
> copy /b license.txt+OpenLayers-closure.js ..\OpenLayers.js
> Hopefully someone will provide a better answer but maybe that will
tide you over until then.
Nice and simple!
looking in build.py, I see comments which refer to a jscompiler.py which
presumably gets renamed to
closure_library_jscompiler. I downloaded that.
Now get.
C:\Program Files\openlayers\build>build.py -c closure full
Merging libraries.
File "C:\Program Files\openlayers\build\build.py", line 117, in <module>
build(args[0], args[1], options=options)
File "C:\Program Files\openlayers\build\build.py", line 55, in build
sourceFiles = mergejs.getNames(sourceDirectory, configFilename)
AttributeError: 'module' object has no attribute 'getNames'
Summit broken here...
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
