AW: [OpenLayers-Users] ArcGIS93Rest - Can't show specific layers
jstylee j_koch10 at hotmail.com
Fri Feb 10 14:28:51 EST 2012
Hey Arnd,
Thanks for the reply.  Even with passing in image for the f part of the
query string, I get the same results - all of the layers.  Would you know
why some ArcGIS Rest service datasets will allow this and some will not?
For instance, OL has an online example of ArcGIS93Rest
(http://openlayers.org/dev/examples/arcgis93rest.html), and using their
example, I was able to show each layer individually by setting the layers
property of the options set as so:
layers: "show:1"
And here is how the GET request looks:
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StateCityHighway_USA/MapServer/export?bbox=-133.32040574214+%2C0.39958686846267%2C-58.1280793754844+%2C75.5919132351182&bboxSR=&layers=show:1&layerdefs=&size=&imageSR=&format=png&transparent=false&dpi=&time=&layerTimeOptions=&f=image
And the layer in OL only displays the layer with an ID of 1.
Do you have any thoughts about this?
Thanks,
jstylee
View this message in context: http://osgeo-org.1560.n6.nabble.com/ArcGIS93Rest-Can-t-show-specific-layers-tp4381519p4384427.html
