[OpenLayers-Users] Map won't center
Lawrence Miller
lawrence.miller at noaa.gov
Mon Feb 13 12:58:27 EST 2012
I get the same effect when I load the script as in the examples.
<script src="http://openlayers.org/api/OpenLayers.js"></script>
<script type="text/javascript">
var map;
function init (){
var options = {
maxExtent: new OpenLayers.Bounds(0,0,1410,913),
maxResolution: "auto"...
</script>
</head>
<body onload="init()" >
<h1 id="title">AAWU Product Layering Test</h1>
<div style="width:696px; height: 425px; border: 1px solid;"
id="map"></div>
</body>
On Sun, Feb 12, 2012 at 8:29 PM, Eric Lemoine
<eric.lemoine at camptocamp.com>wrote:
> On Friday, February 10, 2012, Lawrence Miller <lawrence.miller at noaa.gov>
> wrote:
> > I am trying to load a basemap and layers into a 696x425 frame. The map
> won't appear in the center of the frame, it appears centered low and to the
> left. I can drag the map into the correct location, but I would prefer it
> just appear there. Any suggestions?
> > my script:
> id="map"></div>
> > <script defer="defer" type="text/javascript">
> What if you create the map in an onload callback function as in the
> OpenLayers examples?
> > var options = {
> > var map = new OpenLayers.Map('map',options);
> > var base = new OpenLayers.Layer.Image("Basemap",
> > "newestbasemap.gif",
> > new OpenLayers.Size(1410,913),
> > {isBaseLayer: true}
> > var ice = new OpenLayers.Layer.Image("Freezing Level",
> > "pt3.gif",
> > {isBaseLayer: false,
> > visibility: false,
> > opacity: 0.80}
> > var wind = new OpenLayers.Layer.Image("Wind Speed",
> > "pt3windspd.gif",
> > visibility: false,
> > opacity: 0.60}
> > var turb = new OpenLayers.Layer.Image("Turbulence",
> > "pt3turb.gif",
> > visibility: false,
> > opacity: 0.60}
> > map.addLayers([base, ice, wind, turb]);
> > map.setCenter(new OpenLayers.LonLat(705,456));
> > map.zoomToMaxExtent();
> > map.addControl(new OpenLayers.Control.LayerSwitcher());
> > </script>
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120213/6073b163/attachment.html
