R: Re: Re: [OpenLayers-Users] Hide Overlay Laben in
OpenLayers.Control.LayerSwitcher
francescoboccacci at libero.it
Tue Feb 14 08:05:37 EST 2012
Hi, i tried int his way but it seem that it doesn't work.
Do you have any suggestions?
Thanks
Francesco
>----Messaggio originale----
>Da: ahocevar at opengeo.org
>Data: 14/02/2012 12.46
>A: "francescoboccacci at libero.it"<francescoboccacci at libero.it>
>Cc: <openlayers-users at lists.osgeo.org>
>Ogg: Re: Re: [OpenLayers-Users] Hide Overlay Laben in OpenLayers.Control.
LayerSwitcher
>Oh no, I was hoping you had just added something like the following to
>your application css
>.olControlLayerSwitcher .dataLbl {
> display: none;
>Andreas.
>On Tue, Feb 14, 2012 at 12:41 PM, francescoboccacci at libero.it
><francescoboccacci at libero.it> wrote:
>> Yes, you are right...
>> This is the procedure that i used:
>> 1- I modified the file ../lib/OpenLayers/Control/LayerSwitcher.js in this
way:
>> - I comment all the line that contain dataLbl :
>> * Property: dataLbl
>> * {DOMElement}
>> //dataLbl: null,
>> //this.dataLbl.style.display =
(containsOverlays)
>> ? "" : "none";
>> //this.dataLbl = document.createElement("div");
>> //this.dataLbl.innerHTML = OpenLayers.i18n
>> ("Layers");
>> //OpenLayers.Element.addClass(this.dataLbl,
>> "dataLbl");
>> if (this.ascending) {
>> this.layersDiv.
>> appendChild(this.baseLbl);
>> this.layersDiv.
>> appendChild(this.baseLayersDiv);
>> //this.layersDiv.
>> appendChild(this.dataLbl);
>> this.layersDiv.
>> appendChild(this.dataLayersDiv);
>> } else {
>> //this.layersDiv.
>> this.layersDiv.
>> this.layersDiv.
>> this.layersDiv.
>> after all i recompiled OpenLayers.js file in this way :
>> ../OpenLayers-2.11/build# ./build.py full.cfg OpenLayers.js
>> That's all ... There is anoter way to do that directly into the html file
>> after:
>> map.addControl( new OpenLayers.Control.LayerSwitcher({ ....
>> just add this line:
>> document.getElementsByClassName("dataLbl")[0].innerHTML =""
>> That's all.
>> Francesco Boccacci
>>>Data: 14/02/2012 12.13
>>>Ogg: Re: [OpenLayers-Users] Hide Overlay Laben in OpenLayers.Control.
>> LayerSwitcher
>>>It would be good practice to summarize what was done to solve an
>>>issue, because for people finding this in the archive it is annoying
>>>to only find "I solved it..." without any hints on HOW.
>>>Andreas.
>>>On Tue, Feb 14, 2012 at 11:08 AM, francescoboccacci at libero.it
>>>> Hi all,
>>>> i solved it..
>>>> Francesco
>>>>>Da: francescoboccacci at libero.it
>>>>>Data: 13/02/2012 21.37
>>>>>A: <openlayers-users at lists.osgeo.org>
>>>>>Ogg: [OpenLayers-Users] Hide Overlay Laben in OpenLayers.Control.
>>>> LayerSwitcher
>>>>>Hi all,
>>>>>i would like to hide the Overlay Label in my OpenLayers.Control.
>>>> LayerSwitcher.
>>>>>Is it possible?
>>>>>i tried in this way:
>>>>> dataLbl : "",
>>>>>but it doesn't work.
>>>>>My html file i add :
>>>>><script type="text/javascript" src="OpenLayers-2.11/OpenLayers.js">
>>>>>to read directly to the OpenLayer folder in localserver.
>>>>>I tried also to comment these lines in:
>>>>>../OpenLayers-2.11/lib/OpenLayers/Control/LayerSwitcher.js
>>>>> loadContents: function() {
>>>>> //configure main div
>>>>> OpenLayers.Event.observe(this.div, "mouseup",
>>>>> OpenLayers.Function.bindAsEventListener(this.mouseUp, this));
>>>>> OpenLayers.Event.observe(this.div, "click",
>>>>> this.ignoreEvent);
>>>>> OpenLayers.Event.observe(this.div, "mousedown",
>>>>> OpenLayers.Function.bindAsEventListener(this.mouseDown,
this));
>>>>> OpenLayers.Event.observe(this.div, "dblclick", this.ignoreEvent);
>>>>> // layers list div
>>>>> //this.layersDiv = document.createElement("div");
>>>>> //this.layersDiv.id = this.id + "_layersDiv";
>>>>> //OpenLayers.Element.addClass(this.layersDiv, "layersDiv");
>>>>> this.baseLbl = document.createElement("div");
>>>>> this.baseLbl.innerHTML = OpenLayers.i18n("Base Layer");
>>>>> OpenLayers.Element.addClass(this.baseLbl, "baseLbl");
>>>>> this.baseLayersDiv = document.createElement("div");
>>>>> OpenLayers.Element.addClass(this.baseLayersDiv, "baseLayersDiv");
>>>>> //this.dataLbl.innerHTML = OpenLayers.i18n("Overlay");
>>>>> //this.dataLbl.innerHTML = "<u>"+this.getOverlaysTitle()+"</u>";
>>>>> //OpenLayers.Element.addClass(this.dataLbl, "dataLbl");
>>>>> //this.dataLayersDiv = document.createElement("div");
>>>>> //OpenLayers.Element.addClass(this.dataLayersDiv,
"dataLayersDiv");
>>>>> this.layersDiv.appendChild(this.baseLbl);
>>>>> this.layersDiv.appendChild(this.baseLayersDiv);
>>>>> this.layersDiv.appendChild(this.dataLbl);
>>>>> this.layersDiv.appendChild(this.dataLayersDiv);
>>>>> } else {
>>>>>but it doesn't work. Any suggestion?
>>>>>Thanks
>>>>>Francesco
>>>>>_______________________________________________
>>>>>Users mailing list
>>>>>Users at lists.osgeo.org
>>>>>http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>>> Users mailing list
>>>Andreas Hocevar
>>>OpenGeo - http://opengeo.org/
>>>Expert service straight from the developers.
>Andreas Hocevar
