R: Re: Re: Re: [OpenLayers-Users] Hide Overlay Laben in
OpenLayers.Control.LayerSwitcher
francescoboccacci at libero.it
Tue Feb 14 09:19:34 EST 2012
i will investigate on it.. and i let you know..thanks for your answers..
Francesco
>----Messaggio originale----
>Da: ahocevar at opengeo.org
>Data: 14/02/2012 14.21
>A: "francescoboccacci at libero.it"<francescoboccacci at libero.it>
>Cc: <openlayers-users at lists.osgeo.org>
>Ogg: Re: Re: Re: [OpenLayers-Users] Hide Overlay Laben in OpenLayers.Control.
LayerSwitcher
>Just tried with latest OpenLayers from master, and it works fine for
>me. Maybe you have stronger selector somewhere that takes precedence?
>Andreas.
>On Tue, Feb 14, 2012 at 2:05 PM, francescoboccacci at libero.it
><francescoboccacci at libero.it> wrote:
>> Hi, i tried int his way but it seem that it doesn't work.
>> Do you have any suggestions?
>> Thanks
>> Francesco
>>>Data: 14/02/2012 12.46
>>>Ogg: Re: Re: [OpenLayers-Users] Hide Overlay Laben in OpenLayers.Control.
>> LayerSwitcher
>>>Oh no, I was hoping you had just added something like the following to
>>>your application css
>>>.olControlLayerSwitcher .dataLbl {
>>> display: none;
>>>Andreas.
>>>On Tue, Feb 14, 2012 at 12:41 PM, francescoboccacci at libero.it
>>>> Yes, you are right...
>>>> This is the procedure that i used:
>>>> 1- I modified the file ../lib/OpenLayers/Control/LayerSwitcher.js in this
>> way:
>>>> - I comment all the line that contain dataLbl :
>>>> * Property: dataLbl
>>>> * {DOMElement}
>>>> //dataLbl: null,
>>>> //this.dataLbl.style.display =
>> (containsOverlays)
>>>> ? "" : "none";
>>>> //this.dataLbl = document.createElement
("div");
>>>> //this.dataLbl.innerHTML = OpenLayers.i18n
>>>> ("Layers");
>>>> //OpenLayers.Element.addClass(this.dataLbl,
>>>> "dataLbl");
>>>> if (this.ascending) {
>>>> this.
layersDiv.
>>>> appendChild(this.baseLbl);
>>>> this.
layersDiv.
>>>> appendChild(this.baseLayersDiv);
>>>> //this.
layersDiv.
>>>> appendChild(this.dataLbl);
>>>> this.layersDiv.
>>>> appendChild(this.dataLayersDiv);
>>>> } else {
>>>> //this.
layersDiv.
>>>> this.layersDiv.
>>>> this.layersDiv.
>>>> this.layersDiv.
>>>> after all i recompiled OpenLayers.js file in this way :
>>>> ../OpenLayers-2.11/build# ./build.py full.cfg OpenLayers.js
>>>> That's all ... There is anoter way to do that directly into the html file
>>>> after:
>>>> map.addControl( new OpenLayers.Control.LayerSwitcher({ ....
>>>> just add this line:
>>>> document.getElementsByClassName("dataLbl")[0].innerHTML =""
>>>> That's all.
>>>> Francesco Boccacci
>>>>>Data: 14/02/2012 12.13
>>>>>Ogg: Re: [OpenLayers-Users] Hide Overlay Laben in OpenLayers.Control.
>>>> LayerSwitcher
>>>>>It would be good practice to summarize what was done to solve an
>>>>>issue, because for people finding this in the archive it is annoying
>>>>>to only find "I solved it..." without any hints on HOW.
>>>>>Andreas.
>>>>>On Tue, Feb 14, 2012 at 11:08 AM, francescoboccacci at libero.it
>>>>>> Hi all,
>>>>>> i solved it..
>>>>>> Francesco
>>>>>>>Da: francescoboccacci at libero.it
>>>>>>>Data: 13/02/2012 21.37
>>>>>>>A: <openlayers-users at lists.osgeo.org>
>>>>>>>Ogg: [OpenLayers-Users] Hide Overlay Laben in OpenLayers.Control.
>>>>>> LayerSwitcher
>>>>>>>Hi all,
>>>>>>>i would like to hide the Overlay Label in my OpenLayers.Control.
>>>>>> LayerSwitcher.
>>>>>>>Is it possible?
>>>>>>>i tried in this way:
>>>>>>> dataLbl : "",
>>>>>>>but it doesn't work.
>>>>>>>My html file i add :
>>>>>>><script type="text/javascript" src="OpenLayers-2.11/OpenLayers.js">
>>>>>>>to read directly to the OpenLayer folder in localserver.
>>>>>>>I tried also to comment these lines in:
>>>>>>>../OpenLayers-2.11/lib/OpenLayers/Control/LayerSwitcher.js
>>>>>>> loadContents: function() {
>>>>>>> //configure main div
>>>>>>> OpenLayers.Event.observe(this.div, "mouseup",
>>>>>>> OpenLayers.Function.bindAsEventListener(this.mouseUp,
this));
>>>>>>> OpenLayers.Event.observe(this.div, "click",
>>>>>>> this.ignoreEvent);
>>>>>>> OpenLayers.Event.observe(this.div, "mousedown",
>>>>>>> OpenLayers.Function.bindAsEventListener(this.mouseDown,
>> this));
>>>>>>> OpenLayers.Event.observe(this.div, "dblclick", this.
ignoreEvent);
>>>>>>> // layers list div
>>>>>>> //this.layersDiv = document.createElement("div");
>>>>>>> //this.layersDiv.id = this.id + "_layersDiv";
>>>>>>> //OpenLayers.Element.addClass(this.layersDiv, "layersDiv");
>>>>>>> this.baseLbl = document.createElement("div");
>>>>>>> this.baseLbl.innerHTML = OpenLayers.i18n("Base Layer");
>>>>>>> OpenLayers.Element.addClass(this.baseLbl, "baseLbl");
>>>>>>> this.baseLayersDiv = document.createElement("div");
>>>>>>> OpenLayers.Element.addClass(this.baseLayersDiv,
"baseLayersDiv");
>>>>>>> //this.dataLbl = document.createElement("div");
>>>>>>> //this.dataLbl.innerHTML = OpenLayers.i18n("Overlay");
>>>>>>> //this.dataLbl.innerHTML = "<u>"+this.getOverlaysTitle()+"
</u>";
>>>>>>> //OpenLayers.Element.addClass(this.dataLbl, "dataLbl");
>>>>>>> //this.dataLayersDiv = document.createElement("div");
>>>>>>> //OpenLayers.Element.addClass(this.dataLayersDiv,
>> "dataLayersDiv");
>>>>>>> this.layersDiv.appendChild(this.baseLbl);
>>>>>>> this.layersDiv.appendChild(this.baseLayersDiv);
>>>>>>> this.layersDiv.appendChild(this.dataLbl);
>>>>>>> this.layersDiv.appendChild(this.dataLayersDiv);
>>>>>>> } else {
>>>>>>>but it doesn't work. Any suggestion?
>>>>>>>Thanks
>>>>>>>Francesco
>>>>>>>_______________________________________________
>>>>>>>Users mailing list
>>>>>>>Users at lists.osgeo.org
>>>>>>>http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>>>>> Users mailing list
>>>>>Andreas Hocevar
>>>>>OpenGeo - http://opengeo.org/
>>>>>Expert service straight from the developers.
>>>Andreas Hocevar
>Andreas Hocevar
