R: Re: Re: [OpenLayers-Users] Capture Tile information
francescoboccacci at libero.it
Thu Feb 16 08:08:26 EST 2012
Hi, can you tell me how look at the css class? can you explain it more clear?
Can you write a simple example ?
Thanks in advance...
Francesco
>----Messaggio originale----
>Da: ramotswa at gmail.com
>Data: 16/02/2012 14.02
>A: "francescoboccacci at libero.it"<francescoboccacci at libero.it>
>Cc: <bamerbalazs at gmail.com>, <openlayers-users at lists.osgeo.org>
>Ogg: Re: Re: [OpenLayers-Users] Capture Tile information
>No I understand what you are trying to do, but you can,
>programatically, look at the css class of every tile that comes in
>apparently.
>On 16 February 2012 12:53, francescoboccacci at libero.it
><francescoboccacci at libero.it> wrote:
>> ye..with firebug i can see all requests .. but i'd like to capture the
response
>> from the server if i'm using the tile from my cache or from server(fresh
tile).
>> I don't know if is possible but it will be very interesting.Maybe we have
to
>> work into openlayers code. Thanks
>> Francesco
>>>Da: bamerbalazs at gmail.com
>>>Data: 16/02/2012 13.38
>>>A: <openlayers-users at lists.osgeo.org>
>>>Ogg: Re: [OpenLayers-Users] Capture Tile information
>>>Hi Imran,
>>>> You can see your http request using FireBug, if you are using FireFox.
>>>Yes, but I thought a check during runtime from JavaScript. So that
>>>instead of displaying pink tiles, I would write a message about the
>>>problem with X layer.
>>>best regards: Balázs
>>>_______________________________________________
>>>Users mailing list
>>>Users at lists.osgeo.org
>>>http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Users mailing list
