[OpenLayers-Users] Capture Tile information
Tobias Reinicke
ramotswa at gmail.com
Thu Feb 16 08:59:34 EST 2012
I don't know to be honest, however this person has;
http://lists.osgeo.org/pipermail/openlayers-users/2010-February/015920.html
and it might be worth getting in touch with them.
Toby
On 16 February 2012 13:56, francescoboccacci at libero.it
<francescoboccacci at libero.it> wrote:
> Good solution.. the last question is:
> i can capture if an error is occurs during the tile loading (olImageLoadError)
> , but is possible to check if the tile is already present in my cache (304
> response from server)?
> Thanks again ..
> Francesco
>>----Messaggio originale----
>>Da: ramotswa at gmail.com
>>Data: 16/02/2012 14.48
>>A: "francescoboccacci at libero.it"<francescoboccacci at libero.it>
>>Cc: <bamerbalazs at gmail.com>, <openlayers-users at lists.osgeo.org>
>>Ogg: Re: Re: Re: [OpenLayers-Users] Capture Tile information
>>So if you had an OSM layer.
>>Register an event on tileloaded on it
>> OSMM.events.register("tileloaded", function (e) {
>> var myVar= e;
>>and then somewhere in "myVar" you need to check if "olImageLoadError"
>>is present. One area could be myVar.element.childNodes[0].innerHTML
>>for me that is:
>>"<img id="OpenLayersDiv77" style="position: relative; width: 256px;
>>height: 256px; " class="olTileImage olImageLoadError" src=....>"
>>You can do a text comparison to find if olImageLoadError is in there
>>and report something back accordingly.
>>I have not ever implemented this nor do I think it is a particularly
>>good solution, but it should do what you are after.
>>Toby
>>On 16 February 2012 13:08, francescoboccacci at libero.it
>>> Hi, can you tell me how look at the css class? can you explain it more
> clear?
>>> Can you write a simple example ?
>>> Thanks in advance...
>>> Francesco
>>>>Data: 16/02/2012 14.02
>>>>Ogg: Re: Re: [OpenLayers-Users] Capture Tile information
>>>>No I understand what you are trying to do, but you can,
>>>>programatically, look at the css class of every tile that comes in
>>>>apparently.
>>>>On 16 February 2012 12:53, francescoboccacci at libero.it
>>>>> ye..with firebug i can see all requests .. but i'd like to capture the
>>> response
>>>>> from the server if i'm using the tile from my cache or from server(fresh
>>> tile).
>>>>> I don't know if is possible but it will be very interesting.Maybe we have
>>> to
>>>>> work into openlayers code. Thanks
>>>>> Francesco
>>>>>>Da: bamerbalazs at gmail.com
>>>>>>Data: 16/02/2012 13.38
>>>>>>A: <openlayers-users at lists.osgeo.org>
>>>>>>Ogg: Re: [OpenLayers-Users] Capture Tile information
>>>>>>Hi Imran,
>>>>>>> You can see your http request using FireBug, if you are using FireFox.
>>>>>>Yes, but I thought a check during runtime from JavaScript. So that
>>>>>>instead of displaying pink tiles, I would write a message about the
>>>>>>problem with X layer.
>>>>>>best regards: Balázs
>>>>>>_______________________________________________
>>>>>>Users mailing list
>>>>>>Users at lists.osgeo.org
>>>>>>http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>>>> Users mailing list
