[OpenLayers-Users] Capture Tile information
Andreas Hocevar
ahocevar at opengeo.org
Thu Feb 16 10:33:31 EST 2012
On Thu, Feb 16, 2012 at 4:28 PM, francescoboccacci at libero.it
<francescoboccacci at libero.it> wrote:
> sorry Andreas, my misunderstanding. I would like to try to manage some
> information about traffic request from the server.
You should do that on the server really.
Andreas.
> That's all. Thanks for your suggestions.
> Francesco
>>----Messaggio originale----
>>Da: ahocevar at opengeo.org
>>Data: 16/02/2012 16.20
>>A: "francescoboccacci at libero.it"<francescoboccacci at libero.it>
>>Cc: <openlayers-users at lists.osgeo.org>
>>Ogg: Re: Re: Re: Re: Re: [OpenLayers-Users] Capture Tile information
>>You cannot. All I was saying was that the tileloaded event is also
>>fired for tiles that come from the cache. Why would you want to know
>>which tiles come from the browser cache?
>>Andreas.
>>On Thu, Feb 16, 2012 at 4:15 PM, francescoboccacci at libero.it
>>> Hi Adreas, how is possible capture this information?
>>> I use this code:
>>> layer.events.register("tileloaded", layer, function() {
>>> if (document.getElementsByClassName("olImageLoadError").
>>> length) {
>>> error+=1;
>>> By this way i count the number of tiles that aren't loaded. How can
> capture
>>> the tiles coming from the cache?
>>> Thanks in advance
>>> Francesco
>>>>Data: 16/02/2012 16.08
>>>>Cc: <ramotswa at gmail.com>, <openlayers-users at lists.osgeo.org>
>>>>Ogg: Re: Re: Re: Re: [OpenLayers-Users] Capture Tile information
>>>>No, this is not possible. But the tileloaded event will also fire when
>>>>the image comes from the cache.
>>>>Andreas.
>>>>On Thu, Feb 16, 2012 at 2:56 PM, francescoboccacci at libero.it
>>>>> Good solution.. the last question is:
>>>>> i can capture if an error is occurs during the tile loading
>>> (olImageLoadError)
>>>>> , but is possible to check if the tile is already present in my cache
> (304
>>>>> response from server)?
>>>>> Thanks again ..
>>>>> Francesco
>>>>>>Da: ramotswa at gmail.com
>>>>>>Data: 16/02/2012 14.48
>>>>>>Cc: <bamerbalazs at gmail.com>, <openlayers-users at lists.osgeo.org>
>>>>>>Ogg: Re: Re: Re: [OpenLayers-Users] Capture Tile information
>>>>>>So if you had an OSM layer.
>>>>>>Register an event on tileloaded on it
>>>>>> OSMM.events.register("tileloaded", function (e) {
>>>>>> var myVar= e;
>>>>>>and then somewhere in "myVar" you need to check if "olImageLoadError"
>>>>>>is present. One area could be myVar.element.childNodes[0].innerHTML
>>>>>>for me that is:
>>>>>>"<img id="OpenLayersDiv77" style="position: relative; width: 256px;
>>>>>>height: 256px; " class="olTileImage olImageLoadError" src=....>"
>>>>>>You can do a text comparison to find if olImageLoadError is in there
>>>>>>and report something back accordingly.
>>>>>>I have not ever implemented this nor do I think it is a particularly
>>>>>>good solution, but it should do what you are after.
>>>>>>Toby
>>>>>>On 16 February 2012 13:08, francescoboccacci at libero.it
>>>>>>> Hi, can you tell me how look at the css class? can you explain it more
>>>>> clear?
>>>>>>> Can you write a simple example ?
>>>>>>> Thanks in advance...
>>>>>>> Francesco
>>>>>>>>Data: 16/02/2012 14.02
>>>>>>>>Ogg: Re: Re: [OpenLayers-Users] Capture Tile information
>>>>>>>>No I understand what you are trying to do, but you can,
>>>>>>>>programatically, look at the css class of every tile that comes in
>>>>>>>>apparently.
>>>>>>>>On 16 February 2012 12:53, francescoboccacci at libero.it
>>>>>>>>> ye..with firebug i can see all requests .. but i'd like to capture
> the
>>>>>>> response
>>>>>>>>> from the server if i'm using the tile from my cache or from server
>>> (fresh
>>>>>>> tile).
>>>>>>>>> I don't know if is possible but it will be very interesting.Maybe we
>>> have
>>>>>>> to
>>>>>>>>> work into openlayers code. Thanks
>>>>>>>>> Francesco
>>>>>>>>>>Da: bamerbalazs at gmail.com
>>>>>>>>>>Data: 16/02/2012 13.38
>>>>>>>>>>A: <openlayers-users at lists.osgeo.org>
>>>>>>>>>>Ogg: Re: [OpenLayers-Users] Capture Tile information
>>>>>>>>>>Hi Imran,
>>>>>>>>>>> You can see your http request using FireBug, if you are using
>>> FireFox.
>>>>>>>>>>Yes, but I thought a check during runtime from JavaScript. So that
>>>>>>>>>>instead of displaying pink tiles, I would write a message about the
>>>>>>>>>>problem with X layer.
>>>>>>>>>>best regards: Balázs
>>>>>>>>>>_______________________________________________
>>>>>>>>>>Users mailing list
>>>>>>>>>>Users at lists.osgeo.org
>>>>>>>>>>http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>>>>>>>> Users mailing list
>>>>> Users mailing list
>>>>Andreas Hocevar
>>>>OpenGeo - http://opengeo.org/
>>>>Expert service straight from the developers.
>>> Users mailing list
>>Andreas Hocevar
Andreas Hocevar
