[OpenLayers-Users] Re: Duplicate labels display in ArcGIS Server
REST map service when viewing through OpenLayers API
Andreas Hocevar
ahocevar at opengeo.org
Tue Feb 21 10:22:28 EST 2012
Probably because the map size was too big. Make sure the maximum map
size is big enough in your MapServer map file. You may also want to
configure the ratio option and set it to 1, instead of the 1.5 default
- this will result in a smaller map size being requested from the
server.
Andreas.
On Tue, Feb 21, 2012 at 4:06 PM, crb <chris at windsorsolutions.com> wrote:
> Thanks Andreas.
> I had actually tried that, but it resulted in a broken link, i.e. a
> semi-transparent pink OL layer.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Duplicate-labels-display-in-ArcGIS-Server-REST-map-service-when-viewing-through-OpenLayers-API-tp3910724p4491895.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
