[OpenLayers-Users] How to disable <ctrl> drag
    Ryan Williams
    rwilliams at paqinteractive.com
    Tue Feb 21 11:16:18 EST 2012
Jan,
  There's a short example on the OpenLayers docs that sounds similar.
http://dev.openlayers.org/docs/files/OpenLayers/Control-js.html
It doesn't use the map.events.register though.
It shows how to use OpenLayers.Util.extend to create a control that will
work when the user is holding down the Shift key. It intercepts the
shift-mouse click, lets the user drag out a box, and then does something
with the bounds of that box.
It uses the OpenLayers.Handler.MOD_SHIFT keymask. There is also a
MOD_CTRL keymask you could use as well.
http://dev.openlayers.org/docs/files/OpenLayers/Handler-js.html#OpenLayers.Handler.OpenLayers.Handler.MOD_CTRL
I use the MOD_SHIFT keymask to let users drag out a box over a map and
it works fine.
- Ryan
On 2/21/2012 9:54 AM, Jan Hartmann wrote:
> Hi all,
> I have written a small application to input points with <ctrl><click>
> from an OpenLayers map using
> "map.events.register("click",map,function(e) { ...}". Works fine, but
> when the user moves the mouse when clicking, the default behavior
> takes over: the map is panned and no input takes place. How can I
> disable panning when the <ctrl> key is  down?
> Jan
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Ryan Williams
GIS Analyst / Programmer
PAQ Interactive Inc.
217-762-7955
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120221/d6d94774/attachment.html
