[OpenLayers-Users] OSM base layer + WMS overlay
Andreas Hocevar
ahocevar at opengeo.org
Sun Feb 26 12:29:53 EST 2012
This is not a regression caused by
https://github.com/openlayers/openlayers/pull/219. I don't even think
it is a regression at all - at least I do not remember that this ever
worked, because a layer's maxExtent was never set to the base layer's
maxExtent. @Eric, this is the issue that you and I discussed in
https://github.com/openlayers/openlayers/pull/177.
Andreas.
On Sun, Feb 26, 2012 at 5:01 PM, Eric Lemoine
<eric.lemoine at camptocamp.com> wrote:
> On Thursday, February 23, 2012, François Van Der Biest wrote:
>> Hi guys,
>> This very simple code used to work :
>> map = new OpenLayers.Map({
>> layers: [new OpenLayers.Layer.OSM()]
>> map.addLayers([
>> new OpenLayers.Layer.WMS("test", "/geoserver/wms", {
>> layers: "dept"
>> isBaseLayer: false
>> It does not anymore : the result is a WMS layer whose div is empty.
>> To fix it, I've had to set the map maxExtent to new OpenLayers.Bounds(
>> -128 * 156543.03390625,
>> I find it redundant, since this maxExtent is already defined in
>> OpenLayers.Layer.XYZ (which is extended by OpenLayers.Layer.OSM).
>> Am I doing something wrong or is it a bug ?
> This sounds like a serious regression, probably caused by
> <https://github.com/openlayers/openlayers/pull/219>. Do you use a built
> version of OL or do you observe the problem also when using OL's autoloader?
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
