[OpenLayers-Users] Why won't this map re-center?
Andreas Hocevar ahocevar at opengeo.org
Mon Feb 27 01:59:56 EST 2012
you have to pass the coordinates in the map's SRS (EPSG:900913 for the
OSM layer) to setCenter, and you can combine setCenter with zoomTo. So
the following will center your map at and zoom to zoom level 2:
var wgs84 = new OpenLayers.Projection("EPSG:4326");
var mercator = new OpenLayers.Projection("EPSG:900913");
map.setCenter(
    new OpenLayers.LonLat(-98.4375,39.774769).transform(wgs84, mercator),
    2
Andreas.
On Mon, Feb 27, 2012 at 7:10 AM, Scott Chapman <scott at mischko.com> wrote:
> Here's my code to build a map in the qooxdoo framework.
> The map displays correctly and zooms to the level I tel it to but it
> won't recenter to the LatLon I tell it to.
> Any clues?
> Thanks!
> Scott
> qx.Class.define("kiosk_portal.OpenLayersMap",
>  extend : qx.ui.core.Widget,
>  construct : function()
>      this.base(arguments);
>      this.set({
>        width: 950,
>        height: 650
>      console.log("G A");
>      this.addListenerOnce("appear", function() {
>        var arrayOSM =
> ["http://otile1.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.jpg",
> "http://otile2.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.jpg",
> "http://otile3.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.jpg",
> "http://otile4.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.jpg"];
>        var baseOSM = new OpenLayers.Layer.OSM("MapQuest-OSM Tiles", arrayOSM);
>        var map = new OpenLayers.Map( this.getContentElement().getDomElement(),
>        {controls: [
>            new OpenLayers.Control.PanZoom(),
>            new OpenLayers.Control.ScaleLine(),
>            new OpenLayers.Control.OverviewMap(),
>            new OpenLayers.Control.Navigation(
>                {mouseWheelOptions: {interval: 100}}
>        map.addLayer(baseOSM);
>        map.addControl(new OpenLayers.Control.Attribution());
>        map.setCenter(new OpenLayers.LonLat(-98.4375,39.774769));
>        map.zoomTo(2);
>        this.__map = map;
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
