[OpenLayers-Users] Layer switcher does not work
Mustafa646
noorcs22 at gmail.com
Wed Feb 29 03:35:01 EST 2012
I have added following references on top
I have displayed 3 wms layers over google map and i am using layer switcher
as follows:
map.addLayers([OSM, gmap, gsat, wmslayer1, wmslayer2, wmslayer3]);
var LayerList = new OpenLayers.Control.LayerSwitcher({ 'div':
OpenLayers.Util.getElement('LayerList'), activeColor: '#660066' });
map.addControl(LayerList);
on front end web map , now when i select/unselect layers from layer
switcher, it does not work, and layers do not hide when i unselect any
layer.
also basemap layers dot not change when i select between OSM, gmap, gsat. it
remains as OSM the first layer.
Can anybody explain why suddenly this happen and layers do not hide when i
unselect? Is there any problem with google and openlayers references because
it was working fine since last year.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Layer-switcher-does-not-work-tp4530505p4530505.html
