[OpenLayers-Users] Re: strange behavior with wrong click event
coordinates and drag pan
Andreas Hocevar
ahocevar at opengeo.org
Sat Jan 7 04:26:15 EST 2012
Don't remove the Navigation control, and everything will be fine.
Andreas.
On Fri, Jan 6, 2012 at 11:53 PM, Puneet Kishor <punk.kish at gmail.com> wrote:
> The following behavior still continues...
> On Jan 6, 2012, at 10:50 AM, Puneet Kishor wrote:
>> var map = new OpenLayers.Map("map", {
>> "controls": [
>> - new OpenLayers.Control.LayerSwitcher(),
>> - new OpenLayers.Control.Navigation(),
>> - new OpenLayers.Control.PanZoom(),
>> + new OpenLayers.Control.LayerSwitcher({
>> + "roundedCornerColor": "rgba(0,0,0,0.8)"
>> + new OpenLayers.Control.ZoomPanel(),
>> new OpenLayers.Control.MousePosition({
>> "div": document.getElementById("coords"),
>> "numDigits": 2
>> "projection": new OpenLayers.Projection("EPSG:900913"),
>> "displayProjection": new OpenLayers.Projection("EPSG:4326"),
>> "units": "m",
>> "maxResolution": 156543.0339,
>> "maxExtent": new OpenLayers.Bounds(-20037508, -20037508, 20037508, 20037508)
>> 2. I am unable to drag and pan the map. On the other hand, if I bring back Control.Navigation and Control.PanZoom then I am able to drag pan the map. I want to be able to drag pan the map, but I don't want to show the PanZoom controls. How can I achieve that?
> I can simply not drag the map around. I want to be able to drag the map without showing the pan controls on the top left. How can I do that?
> Many tia,
> Puneet Kishor_______________________________________________
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
