[OpenLayers-Users] the right way to get lon/lat from pixel
Puneet Kishor
punk.kish at gmail.com
Mon Jan 9 14:54:58 EST 2012
I was using the following code without any errors
[A]
var lonlat = map
.getLonLatFromViewPortPx(e.xy)
.transform(proj.google, proj.latlng);
however, I can't find any reference to the above methods anymore in the API docs. On the other hand, I found the following commands, so I changed my code accordingly
[B]
var lonlat = map
.getLonLatFromPixel( this.events.getMousePosition(e) ).
The above works well too, but I just want to confirm if [B] is indeed the way to do it, and if the method in [A] is deprecated.
Puneet Kishor
