[OpenLayers-Users] IE 8/9 Click Handler Single Only triggered by
Double
David Martin
David at itbeyond.com.au
Thu Jan 12 23:58:51 EST 2012
I have been bashing my head against the wall and I think the problem is
in the Click Handler. I am using 2.11 but the problem also is visible in
http://openlayers.org/dev/examples/click-handler.html - using IE if you
select single only you get a double click event showing as a click - I
think this is wrong and it was not the way it used to be in versions
past. Has an issue resurfaced or do I need to do something else to get
double click not triggering a single click in IE.
I am using single to run an AJAX query to return features at the click
and I also use the Navigation control to handle double (left & right )
zoom in/out. I would have thought this typical so I am not sure why my
double click in IE is triggering a DB query.
Any help would be appreciated.
David Martin
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120113/602f7d90/attachment.html
