[OpenLayers-Users] Re: Duplicate labels display in ArcGIS Server REST map service when viewing through OpenLayers API
crb chris at windsorsolutions.com
Thu Jan 19 18:00:28 EST 2012
I am seeing the same thing today with ArcGIS Server v10 SP1 REST services.
I've tried several different labeling options on the server side ('Remove
duplicate labels', 'Place one label per feature', 'Only place label inside
polygon') but OL still displays several labels per polygon feature.  If I
view the same AGS service using the AGS JavaScript API, the labels are
rendered correctly, i.e. one per polygon.
Has anyone else found a workaround for this?
Thanks in advance.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Duplicate-labels-display-in-ArcGIS-Server-REST-map-service-when-viewing-through-OpenLayers-API-tp4902888p7205708.html
