[OpenLayers-Users] Performance issues (memory leak?) with WFS
Hugh.Barker at csiro.au
Sun Jan 22 20:10:57 EST 2012
Hmm, that seems to have fixed the issue - memory stays at a reasonable level.
I should have thought of disabling it before - I knew there was a memory overhead associated with Firebug, but I kind of assumed it would just be a constant overhead - instead it almost looked as if Firebug was preventing garbage collection or something. Oh well, you live and you learn. Thanks for your help.
-----Original Message-----
From: Zac Spitzer [mailto:zac.spitzer at gmail.com]
Sent: Monday, 23 January 2012 11:39
To: Barker, Hugh (CMAR, Hobart)
Cc: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] Performance issues (memory leak?) with WFS
ah, ok...
do you see the same leak issue with firebug completely disabled?
z
On Mon, Jan 23, 2012 at 11:31 AM, <Hugh.Barker at csiro.au> wrote:
> Rendering the points isn't the issue. I'm happy with the performance, especially using clustering.
> The issue is with the refresh strategy, which causes memory issues (it looks like a memory leak) across subsequent updates. Memory usage increases roughly linearly with each update, until the browser crashes.
> Sent: Monday, 23 January 2012 11:27
> WFS
> You simply can't render large amounts of vector data in a browser,
> Firefox and Chrome can handle a lot more vector data than IE, but you
> will always have problems
> On Mon, Jan 23, 2012 at 10:51 AM, <Hugh.Barker at csiro.au> wrote:
>> Hi all,
>> I'm building a web application to display data that is updated in real-time (ship's navigation/sensor underway data). I'm using WFS (served up by a Geoserver/PostGIS backend). The core of it looks like this:
>> underwayWfsProtocol = new OpenLayers.Protocol.WFS.v1_1_0({
>> url: "http://ss-geospatial-hf:8080/geoserver/visage/wfs",
>> featureType: currentVoyage,
>> featureNS: "visage",
>> geometryName: "position"});
>> underwayLayer = new OpenLayers.Layer.Vector("Underway Data", {
>> strategies: [new OpenLayers.Strategy.BBOX(), new
>> OpenLayers.Strategy.Cluster({distance: 10}), new
>> OpenLayers.Strategy.Refresh({interval: 300000, force: true})],
>> //Refresh screen every 60 seconds, cluster points //TODO -
>> performance issues
>> protocol: underwayWfsProtocol,
>> styleMap: new OpenLayers.StyleMap({ //TODO - dynamic styling based
>> on zoom level etc, make latest point different
>> pointRadius: 3,
>> fillColor: "#ff0000" })});
>> map = new OpenLayers.Map({
>> div: "map",
>> layers: [baseLayer = new OpenLayers.Layer.WMS(
>> "Bathymetry",
>> "http://ss-geospatial-hf:8080/geoserver/visage/wms",
>> {layers: "visage:bathytopo2005tif"})],
>> center: baseLayerBounds.getCenterLonLat(),
>> zoom: 4});
>> map.addLayer(underwayLayer);
>> I also have some other standard bits and pieces, like a graticule, popups on feature select and so on. Nothing too unusual.
>> My problem is with performance - my development platform is Firefox 9.0.1, Win7 64. The map and features load fine initially, however after a number of updates (via the refresh strategy) Firefox's memory usage will balloon, crashing Firefox (and sometimes my whole system) in fairly short order. I've tried with both OpenLayers 2.11 and the latest trunk version.
>> Any advice would be great - I'm at a bit of a loss. If at all possible I'd like to stick with the WFS approach, as the functionality is a good fit for my application vs WMS - just not the performance.
>> Cheers,
>> Hugh Barker
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
> Users mailing list
Zac Spitzer
+61 405 847 168
