[OpenLayers-Users] Layer.OSM / Layer.XYZ: show only a subset
of all available resolutions
Marc Jansen
jansen at terrestris.de
Tue Jan 24 15:39:37 EST 2012
Hi Andreas,
helpfull as always! This is indeed a very cool addition to OpenLayers. I
will see if the application in question can move to git-master.
Thanks a lot and kind regards,
Marc
On 24.01.2012 15:20, Andreas Hocevar wrote:
> Not with the 2.11 release, but with current master (this was fixed
> shortly after the release):
> new OpenLayers.Map({
> div: "map",
> layers: [new OpenLayers.Layer.OSM(null, null, {
> resolutions: [76.43702827148438, 19.109257067871095],
> serverResolutions: [156543.03390625, 78271.516953125,
> 39135.7584765625, 19567.87923828125, 9783.939619140625,
> 4891.9698095703125, 2445.9849047851562, 1222.9924523925781,
> 611.4962261962891, 305.74811309814453, 152.87405654907226,
> 76.43702827453613, 38.218514137268066, 19.109257068634033,
> 9.554628534317017, 4.777314267158508, 2.388657133579254,
> 1.194328566789627, 0.5971642833948135, 0.29858214169740677,
> 0.14929107084870338, 0.07464553542435169]
> center: new OpenLayers.LonLat(16.37, 48.21).transform(
> new OpenLayers.Projection("EPSG:4326"),
> new OpenLayers.Projection("EPSG:900913")
> Andreas.
> On Tue, Jan 24, 2012 at 2:31 PM, Marc Jansen<jansen at terrestris.de> wrote:
>> Hi list,
>> I currently fail at implementing the following:
>> Build a map that has a OpenLayers.Layer.OSM-layer, but which will only
>> display some of the possible zoomlevels, e.g. only the zoomlevel 11
>> (resolution = 76.43702827148438) and the zoomlevel 13 (resolution =
>> 19.109257067871095).
>> This sounds easy at first... but yet I am struggling with this. I tried
>> numerous combinations of resolutions, serverResolutions and zoomOffset but
>> without success. Is this doable with current 2.11-API?
>> Thanks for any help on this.
>> Best regards,
>> Marc
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
