[OpenLayers-Users] SVG related error
Takako Tucker Takako.Tucker at bbc.co.uk
Thu Jan 26 07:24:50 EST 2012
Hi Andreas
I was just going to send a follow up post.
It's been fixed.
This is a bit of insights..
Background:
We have two tabs, fist one shows up a static map image, another shows
the OL map.
To achieve these tab navigations, we needed to add "display:none" by
javascript to hide one of the containers.
Issue:
As the second tab contained OL map and the tab container defaults to
display:none when loading, width and height assigned to map div was
getting removed and throwing an error.
So we did:
Create a function to makeMap then only triggers it when the second tab
was clicked.
Thanks as always for your support.
takako
-----Original Message-----
From: andreas.hocevar at gmail.com [mailto:andreas.hocevar at gmail.com] On
Behalf Of Andreas Hocevar
Sent: 26 January 2012 12:06
To: Takako Tucker
Cc: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] SVG related error
can you post a minimal example map that produces these errors?
Thanks,
Andreas.
On Tue, Jan 24, 2012 at 6:24 PM, Takako Tucker <Takako.Tucker at bbc.co.uk>
wrote:
> Hello,
> I've got .map in my html and that's got width and height.
> The map shows up fine, but throws these errors:
> Unexpected value NaN parsing width attribute.
> Unexpected value NaN parsing height attribute.
> Unexpected value 0 0 NaN NaN parsing viewBox attribute.
> I had a look at the code in Firebug and looks like this line is
> causing these errors
> <svg id="OpenLayers.Layer.Vector_27_svgRoot" width="NaN" height="NaN"
> viewBox="0 0 NaN NaN"/>
> Does anyone know why it's happening?
> Thanks
> Takako
> http://www.bbc.co.uk
> This e-mail (and any attachments) is confidential and may contain
> personal views which are not the views of the BBC unless specifically
stated.
> If you have received it in error, please delete it from your system.
> Do not use, copy or disclose the information in any way nor act in
> reliance on it and notify the sender immediately.
> Please note that the BBC monitors e-mails sent or received.
> Further communication will signify your consent to this.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
http://www.bbc.co.uk/
This e-mail (and any attachments) is confidential and may contain personal views which are not the views of the BBC unless specifically stated.
Do not use, copy or disclose the information in any way nor act in reliance on it and notify the sender immediately.
