[OpenLayers-Users] mousewheel jumps two zoom levels
Daniel Behr daniel.behr at hzg.de
Thu Jan 26 10:41:53 EST 2012
I'm facing a similar problem, but for my app its a cross-browser issue
on windows machines only! on linux its fine and the map has only one
Navigation Control.
does this help to spot the problem?
Daniel
Am 26.01.2012 16:25, schrieb Andreas Hocevar:
> My guess is that you have two Navigation controls. One that is added
> to the map by default unless you configure it with your custom array
> of controls, and the navControl you added.
> You can check in the javascript console by trying
> map.getControlsByClass("OpenLayers.Control.Navigation");
> and see if it returns an array of length 1 or 2.
> The obvious fix is to configure the map with your own default set of controls.
> Andreas.
> On Thu, Jan 26, 2012 at 3:29 PM, Vidal, Antoni<antoni.vidal at icc.cat>  wrote:
>> Hi list,
>> I’ve an OpenLayers.control.Navigation with following config options:
>>          var navControl = new OpenLayers.Control.Navigation({
>>              type: OpenLayers.Control.TYPE_TOGGLE,
>>              zoomWheelEnabled: true,
>>              mouseWheelOptions: {interval: 1}
>> But when user changes map zoom level using mousewheel, map zoomlevel jumps
>> from 0 to 2 and then to 4, etc.
>> Is possible to change this behaviour and force change zoomlevel one by one ?
>> Thanks in advance.
>> Antoni Vidal
>> Unitat d'Aplicacions SIG-WEB
>> Institut Cartogràfic de Catalunya
>> Parc de Montjuïc, E-08038 Barcelona
>> Tel. (+34) 93 567 15 00 (ext. 3228)
>> www.icc.cat
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Daniel Behr
Institut für Küstenforschung
WebGIS Entwicklung
+49 (0)4152 87 1589 (fax -1596)
Daniel.Behr at hzg.de
Helmholtz-Zentrum Geesthacht
Zentrum für Material- und Küstenforschung GmbH
Max-Planck-Straße 1 I 21502 Geesthacht I Deutschland/Germany
Geschäftsführer/Board of Management: Prof. Dr. Wolfgang Kaysser, Dipl.-Ing. Michael Ganß
Vorsitzender des Aufsichtsrates/Chairman of the Supervisory Board: MinDirig Wilfried Kraus
Amtsgericht Lübeck HRB 285 GE (Register Court)
Internet: http://www.hzg.de
