[OpenLayers-Users] Re: overlaying tiled WMS on top of bing
Andreas Hocevar
ahocevar at opengeo.org
Thu Jan 26 13:50:57 EST 2012
you put most layer options in the layer params object, and you should
set the maxExtent on the WMS layer. Something like
tiled = new OpenLayers.Layer.WMS(
"dwt_lata_proj - Untiled",
"http://localhost:8080/geoserver/wms",
layers: 'DWT:dwt_lata_proj',
styles: '',
format: format,
transparent:true,
numZoomLevels:19,
maxExtent: new OpenLayers.Bounds(
-19840232, 2028971.375,
-7262943, 11534410
minResolution:0.5971642833948135,
maxResolution:156543.03390625,
singleTile: true,
ratio: 1
The above should work both with singleTile: true and without.
Andreas.
On Thu, Jan 26, 2012 at 7:44 PM, Kjel Anderson
<kanderson at truevectortech.com> wrote:
> Looking at it now I see the version that is working "best" is with the wms
> layer being untiled.
> function init(){
> // if this is just a coverage or a group of them, disable a
> few items,
> // and default to jpeg format
> format = 'image/png';
> var bounds = new OpenLayers.Bounds(
> -7262943, 11534410
> var options = {
> controls: [],
> maxResolution: 49130.03515625,
> projection: "EPSG:900913",
> units: 'm'
> map = new OpenLayers.Map('map', options);
> var road = new OpenLayers.Layer.Bing({
> key: apiKey,
> type: "Road"
> var hybrid = new OpenLayers.Layer.Bing({
> key: apiKey,
> type: "AerialWithLabels"
> var aerial = new OpenLayers.Layer.Bing({
> key: apiKey,
> type: "Aerial"
> map.addLayers([road, hybrid, aerial]);
> width: '512',
> srs: 'EPSG:900913',
> height: '386',
> styles: '',
> format: format,
> transparent:true,
> numZoomLevels:19,
> {singleTile: true, ratio: 1}
> map.addLayer(untiled);
> // build up all controls
> map.addControl(new OpenLayers.Control.PanZoomBar({
> position: new OpenLayers.Pixel(2, 15)
> map.addControl(new OpenLayers.Control.Navigation());
> map.addControl(new OpenLayers.Control.Scale($('scale')));
> map.addControl(new OpenLayers.Control.MousePosition({element:
> $('location')}));
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> On Thu, Jan 26, 2012 at 10:33 AM, maw269 <maw269 at gmail.com> wrote:
>> Is your bing layer imagery? I've had nothing but issues combining layers
>> with
>> Bing Imagery layers.
>> Anyhow, can you post the relevant code so we could take a look?
>> --Matt
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/overlaying-tiled-WMS-on-top-of-bing-tp4341145p4341275.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
