[OpenLayers-Users] Re: overlaying tiled WMS on top of bing
Andreas Hocevar
ahocevar at opengeo.org
Thu Jan 26 14:47:50 EST 2012
You didn't make the changes that we recommended. The key to solving
this is the maxExtent on the WMS layer. Here's a fiddle with a
simplified version of your code and your layer, to show that it works:
http://jsfiddle.net/ZVaXh/
It doesn't matter if it's Bing or OSM, you have to configure your WMS
layer the right way.
Andreas.
On Thu, Jan 26, 2012 at 8:35 PM, Kjel Anderson
<kanderson at truevectortech.com> wrote:
> You know, Bing is incidental in this whole thing. I'd rather be using OSM as
> the background layer but I couldn't get that to work at all. Does anyone
> have a working example of this with any base layer?
> On Thu, Jan 26, 2012 at 11:32 AM, Kjel Anderson
>> That's still not doing it but I'm noticing that the layers turns on when I
>> pan to the edge of the map. What controls that?
>> On Thu, Jan 26, 2012 at 11:28 AM, Andreas Hocevar <ahocevar at opengeo.org>
>> wrote:
>>> You still forgot to set the maxExtent on your WMS layer!
>>> Andreas.
>>> On Thu, Jan 26, 2012 at 8:11 PM, Kjel Anderson
>>> > Hmmm. No dice with these changes incorporated. I'm not sure what is
>>> > going
>>> > on. For the curious there is a live link here:
>>> > http://truevector.skygone.net:8080/DWTEdstest/
>>> > On Thu, Jan 26, 2012 at 10:50 AM, Andreas Hocevar
>>> > wrote:
>>> >> Hi,
>>> >> you put most layer options in the layer params object, and you should
>>> >> set the maxExtent on the WMS layer. Something like
>>> >> tiled = new OpenLayers.Layer.WMS(
>>> >> "dwt_lata_proj - Untiled",
>>> >> "http://localhost:8080/geoserver/wms",
>>> >> layers: 'DWT:dwt_lata_proj',
>>> >> styles: '',
>>> >> format: format,
>>> >> transparent:true,
>>> >> numZoomLevels:19,
>>> >> maxExtent: new OpenLayers.Bounds(
>>> >> -19840232, 2028971.375,
>>> >> -7262943, 11534410
>>> >> minResolution:0.5971642833948135,
>>> >> maxResolution:156543.03390625,
>>> >> singleTile: true,
>>> >> ratio: 1
>>> >> The above should work both with singleTile: true and without.
>>> >> Andreas.
>>> >> On Thu, Jan 26, 2012 at 7:44 PM, Kjel Anderson
>>> >> > Looking at it now I see the version that is working "best" is with
>>> >> > the
>>> >> > wms
>>> >> > layer being untiled.
>>> >> > function init(){
>>> >> > // if this is just a coverage or a group of them,
>>> >> > disable a
>>> >> > few items,
>>> >> > // and default to jpeg format
>>> >> > format = 'image/png';
>>> >> > var bounds = new OpenLayers.Bounds(
>>> >> > -7262943, 11534410
>>> >> > var options = {
>>> >> > controls: [],
>>> >> > maxResolution: 49130.03515625,
>>> >> > projection: "EPSG:900913",
>>> >> > units: 'm'
>>> >> > map = new OpenLayers.Map('map', options);
>>> >> > var road = new OpenLayers.Layer.Bing({
>>> >> > key: apiKey,
>>> >> > type: "Road"
>>> >> > var hybrid = new OpenLayers.Layer.Bing({
>>> >> > key: apiKey,
>>> >> > type: "AerialWithLabels"
>>> >> > var aerial = new OpenLayers.Layer.Bing({
>>> >> > key: apiKey,
>>> >> > type: "Aerial"
>>> >> > map.addLayers([road, hybrid, aerial]);
>>> >> > width: '512',
>>> >> > srs: 'EPSG:900913',
>>> >> > height: '386',
>>> >> > styles: '',
>>> >> > format: format,
>>> >> > transparent:true,
>>> >> > numZoomLevels:19,
>>> >> > {singleTile: true, ratio: 1}
>>> >> > map.addLayer(untiled);
>>> >> > // build up all controls
>>> >> > map.addControl(new OpenLayers.Control.PanZoomBar({
>>> >> > position: new OpenLayers.Pixel(2, 15)
>>> >> > map.addControl(new OpenLayers.Control.Navigation());
>>> >> > map.addControl(new
>>> >> > OpenLayers.Control.Scale($('scale')));
>>> >> > map.addControl(new
>>> >> > OpenLayers.Control.MousePosition({element:
>>> >> > $('location')}));
>>> >> > map.addControl(new OpenLayers.Control.LayerSwitcher());
>>> >> > On Thu, Jan 26, 2012 at 10:33 AM, maw269 <maw269 at gmail.com> wrote:
>>> >> >> Is your bing layer imagery? I've had nothing but issues combining
>>> >> >> layers
>>> >> >> with
>>> >> >> Bing Imagery layers.
>>> >> >> Anyhow, can you post the relevant code so we could take a look?
>>> >> >> --Matt
>>> >> >> View this message in context:
>>> >> >> http://osgeo-org.1560.n6.nabble.com/overlaying-tiled-WMS-on-top-of-bing-tp4341145p4341275.html
>>> >> >> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> >> >> _______________________________________________
>>> >> >> Users mailing list
>>> >> >> Users at lists.osgeo.org
>>> >> >> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>> >> > Users mailing list
>>> >> Andreas Hocevar
>>> >> OpenGeo - http://opengeo.org/
>>> >> Expert service straight from the developers.
>>> > Users mailing list
>>> Andreas Hocevar
Andreas Hocevar
