[OpenLayers-Users] Re: How to test if a point is within WMS layer?
maw269
maw269 at gmail.com
Thu Jan 26 16:23:10 EST 2012
Andreas wrote:"That's right. If that's not what you need, then you probably
need
topology rule enforcement. I assume you want to persist the user
generated geometries on your GeoServer as well? That can be done as
part of WFS transactions, using pre- and post-transaction hooks on the
server. The first step would be to see why your GeoServer does not
respond to WFS request, but that's a question for the geoserver-users
list."
I don't have any user generated geometries for this scenario. I simply want
to test whether a point is within a polygon geometry sitting on GeoServer. I
figured out the GeoServer is actually responding to the WFS request for the
polygon but there are LOTS of vertices so it not feasible to use the WFS
approach to determine whether the point is within the polygon.
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-test-if-a-point-is-within-WMS-layer-tp4341265p4341729.html
