[OpenLayers-Users] wrong displayed projection
Bán Miklós
banm at vocs.unideb.hu
Fri Jan 27 01:27:40 EST 2012
Dear all,
I have a problem with projections in wms layers,
I have two wms layers from mapserv and i have two data sources
an shp and a postgis. I produced the postgis table from the shp.
When I load these two layers in qgis, they are overlapping as I
expected, but if you check it here
(http://biomaps.unideb.hu/openlayers/mapserv_test.html) the postgis
layer center is 0,0 while the shp data layer is right.
Where is the error?
Thank you very much, Miklos
The related openlayers js (I willing to use google base layers...)
var options = {
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
units: "m",
numZoomLevels: 20,
maxResolution: 156543.0339,
maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
20037508, 20037508.34),
map = new OpenLayers.Map( 'map',options);
layer2 = new OpenLayers.Layer.WMS( "shp",
"http://biomaps.unideb.hu/cgi-bin/mapserv",{
map:'/home/banm/maps/minimal.map',layers:'0605',
isBaseLayer: false,
visibility:true,
opacity:1.0,
format:'image/png',
//transparent:true,
layer2p = new OpenLayers.Layer.MapServer( "postgis",
"http://biomaps.unideb.hu/cgi-bin/mapserv", {
map: '/home/banm/maps/minimalp.map',
layers:'cuckoo_feszkek',
isBaseLayer: false,
visibility:true,
opacity:1.0,
format:'image/png',
transparent:true,
the shp mapfile:
MAP
NAME "QGIS-MAP"
SIZE 200 200
SYMBOLSET ./points.sym
DEBUG 0
SHAPEPATH "../SHP/"
PROJECTION
"init=epsg:4326"
END
WEB
IMAGEPATH '/tmp/'
IMAGEURL '/tmp/'
END
IMAGEQUALITY 95
IMAGETYPE agg
OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG
IMAGEMODE RGB
END
LAYER
name "0605"
STATUS DEFAULT
DATA "feszkek.shp"
TYPE point
CLASS
SYMBOL "circle_filled"
color 123 70 23
SIZE 6
END #class
END
END
The postgis layer:
layer
name 'feszkek'
status default
type point
connectiontype postgis
connection "host=localhost dbname=** password=**
user=gisadmin" data "the_geom from feszkek"
class
color 12 70 23
SIZE 6
end
end
Miklós Bán
Behavioural Ecology Research Group
Department of Evolutionary Zoology
http://vocs.unideb.hu/banm
University of Debrecen
H-4010 Debrecen, Egyetem tér 1.
Phone: +36 52 512-900 ext. 62356
