[OpenLayers-Users] mousewheel jumps two zoom levels
Daniel Behr
daniel.behr at hzg.de
Fri Jan 27 02:20:45 EST 2012
thanks Andreas, this works fine for me...
Am 26.01.2012 16:51, schrieb Andreas Hocevar:
> Hi,
> whether one tick on the mouse wheel is one zoom level or not depends
> on the mouse sensitivity, which is a system-wide setting. You can,
> however, pass something like
> mouseWheelOptions: {interval: 20, cumulative: false}
> to the Navigation control, and it will only change the zoom by 1 for a
> 20ms drag. You can try this setting online here:
> http://openlayers.org/dev/examples/mobile-wmts-vienna.html
> Andreas.
> On Thu, Jan 26, 2012 at 4:41 PM, Daniel Behr<daniel.behr at hzg.de> wrote:
>> I'm facing a similar problem, but for my app its a cross-browser issue on
>> windows machines only! on linux its fine and the map has only one Navigation
>> Control.
>> does this help to spot the problem?
>> Daniel
>> Am 26.01.2012 16:25, schrieb Andreas Hocevar:
>>> My guess is that you have two Navigation controls. One that is added
>>> to the map by default unless you configure it with your custom array
>>> of controls, and the navControl you added.
>>> You can check in the javascript console by trying
>>> map.getControlsByClass("OpenLayers.Control.Navigation");
>>> and see if it returns an array of length 1 or 2.
>>> The obvious fix is to configure the map with your own default set of
>>> controls.
>>> Andreas.
>>> On Thu, Jan 26, 2012 at 3:29 PM, Vidal, Antoni<antoni.vidal at icc.cat>
>>> wrote:
>>>> Hi list,
>>>> I’ve an OpenLayers.control.Navigation with following config options:
>>>> var navControl = new OpenLayers.Control.Navigation({
>>>> type: OpenLayers.Control.TYPE_TOGGLE,
>>>> zoomWheelEnabled: true,
>>>> mouseWheelOptions: {interval: 1}
>>>> But when user changes map zoom level using mousewheel, map zoomlevel
>>>> jumps
>>>> from 0 to 2 and then to 4, etc.
>>>> Is possible to change this behaviour and force change zoomlevel one by
>>>> one ?
>>>> Thanks in advance.
>>>> Antoni Vidal
>>>> Unitat d'Aplicacions SIG-WEB
>>>> Institut Cartogràfic de Catalunya
>>>> Parc de Montjuïc, E-08038 Barcelona
>>>> Tel. (+34) 93 567 15 00 (ext. 3228)
>>>> www.icc.cat
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Daniel Behr
>> Institut für Küstenforschung
>> WebGIS Entwicklung
>> +49 (0)4152 87 1589 (fax -1596)
>> Daniel.Behr at hzg.de
>> Helmholtz-Zentrum Geesthacht Zentrum für Material- und Küstenforschung GmbH
>> Max-Planck-Straße 1 I 21502 Geesthacht I Deutschland/Germany
>> Geschäftsführer/Board of Management: Prof. Dr. Wolfgang Kaysser, Dipl.-Ing.
>> Michael Ganß Vorsitzender des Aufsichtsrates/Chairman of the Supervisory
>> Board: MinDirig Wilfried Kraus Amtsgericht Lübeck HRB 285 GE (Register
>> Court) Internet: http://www.hzg.de
>> Users mailing list
Geschäftsführer/Board of Management: Prof. Dr. Wolfgang Kaysser, Dipl.-Ing. Michael Ganß
Vorsitzender des Aufsichtsrates/Chairman of the Supervisory Board: MinDirig Wilfried Kraus
Amtsgericht Lübeck HRB 285 GE (Register Court)
