[OpenLayers-Users] Move listener curious behaviour
Andreas Hocevar ahocevar at opengeo.org
Tue Jan 31 09:15:48 EST 2012
getLonLatFromLayerPx is an internal function that does not what you
want and should not be used by applications. Try getLonLatFromPixel
instead.
Andreas.
On Tue, Jan 31, 2012 at 3:05 PM, Tobias Reinicke <ramotswa at gmail.com> wrote:
> Hello all,
> I have spotted some curious behaviour with the move listener on the
> map object. (using OL 2.11).
> The code is pretty simple..
> map = new OpenLayers.Map({
>    controls: [new OpenLayers.Control.Navigation() ],
>    div: "map",
>    eventListeners: {
>        "move": updateCoord
> and the updatecoord function is just this:
>   function updateMap() {
>                 var tlPixel = new OpenLayers.Pixel(10,10);
>                var tl = map.getLonLatFromLayerPx(tlPixel);
>                document.getElementById('output').innerHTML = tl.toString();
> The problem I'm seeing is that the coordinates are only updated every
> time I zoom, rather than everytime I pan / drag etc...
> Any ideas?
> Thanks,
> Toby
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
