[OpenLayers-Users] here is the link of example?
sacprasanna sacprasanna at gmail.com
Mon Jul 2 04:34:47 PDT 2012
Really Thanks ,I am working on your link
On 7/2/12, slohamanoj [via OSGeo.org]
<ml-node+s1560n4985209h7 at n6.nabble.com> wrote:
> Hi,
> You need to customize the featureinfo for each layers residing in
> geoserver/datadir/workspaces/(workspace name ex.
> topp)/layers(states_shapefile)/states/add(content.ftl,
> header.ftl,footer.ftl)
> So by adding the necessary fields in content.ftl you can get your
> FeatureInfo Popup as you need.
> Refer:
> http://docs.geoserver.org/trunk/en/user/tutorials/GetFeatureInfo/index.html#custom-templates
> http://comments.gmane.org/gmane.comp.gis.geoserver.user/30206
> Best Regards,
> gis.slokam
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/How-show-some-fields-only-when-using-WMSGetFeatureInfo-tp4984749p4985209.html
> To unsubscribe from How show some fields only when using WMSGetFeatureInfo?,
> visit
> http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4984749&code=c2FjcHJhc2FubmFAZ21haWwuY29tfDQ5ODQ3NDl8LTIwMzA3MDM5NjY=
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-show-some-fields-only-when-using-WMSGetFeatureInfo-tp4984749p4985316.html
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120702/392f370d/attachment.html>
