[OpenLayers-Users] Slow WFS filter layer
Paul Meems
bontepaarden at gmail.com
Mon Jul 2 12:53:38 PDT 2012
Hi Milo,
Thanks for the quick reply.
1. Yes, GeoServer and PostGIS are on the same server (dedicated server @
RackSpace)
2. What is enough RAM? I now have 2GB, with only Ubuntu, GeoServer and
3. My dataset has 67k features. I can try tomorrow with a smaller dataset.
4. I'm using FF v13 with FireBug.
5. I'll also try the empty string as initial filter.
Here's a live sample:
http://demo.smartdakscan.nl/zonnekaart.php (in Dutch).
Thanks,
Paul
2012/7/2 Milo van der Linden <milo at dogodigi.net>
> I am doing something similar, but my initial filter is an empty string ""
> that gets set to a valid string later on. I do not use an id, but use the
> filter to limit results to a viewers organizational unit. I have seen over
> a hunderd features displayed in less then a second. The underlying table is
> oracle spatial with less then 10k records.
> To dig in deeper:
> 1. Are geoserver and your db on the same machine?
> 2. Do you have enough RAM?
> 3. Did you test smaller datasets which generate the same result and are
> they faster?
> 4. What browser are you using?
> On Jul 2, 2012 9:18 PM, "Paul Meems" <bontepaarden at gmail.com> wrote:
>> I use GeoServer and PostGIS and OpenLayers to show the data.
>> For one page I'm using a WFS layer and I filter on address.
>> The user first need to select an address. This is done with an AJAX call
>> and the adresID and the location (X, Y) are returned.
>> I zoom to that location and change my filter.
>> This is my initial set-up of my layer, an addressID of -1 doesn't exists
>> so it starts with just the baselayer:
>> var myLayer = new OpenLayers.Layer.Vector("tmp", { displayInLayerSwitcher: true, strategies: [new OpenLayers.Strategy.BBOX()], filter: new OpenLayers.Filter.Comparison({ type: OpenLayers.Filter.Comparison.EQUAL_TO, property: "_adresid", value: "-1"}), styleMap: new OpenLayers.StyleMap(), protocol: new OpenLayers.Protocol.WFS({ url: ".../wfs", featureType: "myName", srsName: "EPSG:3857", geometryName: "geomgoogle" })});
>> But this call takes long because it tries to find the -1 value.
>> *Q1*: How can I add a WFS layer without data?
>> And this is the method I call after the user selects an address:
>> function changeFilter(newValue, x, y){ myLayer.destroyFeatures(); filter = new OpenLayers.Filter.Logical({ type: OpenLayers.Filter.Logical.AND, filters: [ new OpenLayers.Filter.Comparison({ type: OpenLayers.Filter.Comparison.EQUAL_TO, property: "_adresid", value: newValue }), new OpenLayers.Filter.Spatial({ type: OpenLayers.Filter.Spatial.BBOX, value: new OpenLayers.Bounds(x-50, y-50, x+50, y+50), projection: "EPSG:3857" }) ] }); myLayer.filter = filter; myLayer.refresh({force: true});
>> showAttributes();
>> This is working great, but is does take a very long time: about 7-10
>> seconds.
>> The result are just a few features: 3-10
>> Of course I have an index in the database on _adresid and a spatial index.
>> *Q2*: What else can I do to speed up this filter?
>> Thanks,
>> Paul
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120702/0872bb51/attachment.html>
