[OpenLayers-Users] Fwd: my vector data don't show up - wfs
Gery . gamejihou at hotmail.com
Thu Jul 5 11:19:13 PDT 2012
Nice to hear that it finally work!, enjoy it =)
Cheers,
Gery
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
> Date: Thu, 5 Jul 2012 19:14:43 +0100
> From: pedrocostaarma at sapo.pt
> To: gamejihou at hotmail.com; openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
> Gery and others,
> Thank you for your help. Now i can see WFS on html page (ubuntu)!!!!!!!!
> I'm just add host 'mydomain:8080' to allowed host in proxy file, change
> the path to python and put a missing '...
> Thank you to all
> Em 05-07-2012 18:05, Gery . escreveu:
> > Hello Pedro,
> > uhmm one question, where did you put your html file? I work in rhel and my directories are in /var/www/html/
> > Cheers,
> > Gery
> >> Date: Thu, 5 Jul 2012 16:28:04 +0100
> >> Thanks for helping me.
> >> I move my html files to a ubuntu server for testing and now i can't put
> >> proxy to work...
> >> Apache give me this error:
> >> (13)Permission denied: exec of
> >> '/var/www/pmapper-4.2.0/cgi-bin/proxy.py' failed
> >> Premature end of script headers: proxy.py
> >> Does anybody know the cause?
> >> Thanks
> >> Em 04-07-2012 18:30, Gery . escreveu:
> >> It seems that firefox should be the problem, people tried the php code
> >> and that worked for them. The error in firebug gives you something else
> >> that may help to trace the source of error?
> >> si NO es necesario.
> >> Date: Wed, 4 Jul 2012 18:02:59 +0100
> >> From: pedrocostaarma at sapo.pt<mailto:pedrocostaarma at sapo.pt>
> >> To: gamejihou at hotmail.com<mailto:gamejihou at hotmail.com>;
> >> openlayers-users at lists.osgeo.org<mailto:openlayers-users at lists.osgeo.org>
> >> Thanks for your help Gery.
> >> I'm already tried with others browsers but the wfs doesn't show up.
> >> I had found some links that you tell me.
> >> I am tried a lot of alternatives and I not discovered the problem.
> >> You think the problem is firefox? If so why not appear in the IE wfs?
> >> I'm confused
> >> Em 04-07-2012 17:55, Gery . escreveu:
> >> This one may help you also, it worked for some people out there:
> >> http://www.webdeveloper.com/forum/showthread.php?t=187247
> >> Cheers,
> >> si NO es necesario.
> >> From: gamejihou at hotmail.com<mailto:gamejihou at hotmail.com>
> >> To: pedrocostaarma at sapo.pt<mailto:pedrocostaarma at sapo.pt>;
> >> Subject: RE: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
> >> Date: Wed, 4 Jul 2012 16:52:22 +0000
> >> Hi Pedro,
> >> I was reading about this error in google and it seems that this is one
> >> of the solutions, you have to use this: var url = 'proxy_php.php?fn=' +
> >> encodeURIComponent(src);
> >> it seems that the problem is ajax (as far I understand), but it can be
> >> firefox, try first in IE or safari to see what happens. Also this page
> >> is suggested about the php code above:
> >> http://developer.yahoo.com/javascript/howto-proxy.html
> >> This page is in spanish, it may help you:
> >> http://www.forosdelweb.com/f127/ayuda-access-restricted-uri-denied-599455/
> >> Cheers,
> >> Gery
> >> si NO es necesario.
> >> Date: Wed, 4 Jul 2012 15:04:39 +0100
> >> Thank you Gery.
> >> Now my proxy is working but i got this error in firebug:
> >> 'Access to restricted URI denied'
> >> My code:
> >> http://pastebin.com/AGAFGSfn
> >> Em 04-07-2012 11:37, Gery . escreveu:
> >> Hi Pedro,
> >> Glad to hear that it was useful to you and it worked. Well, I think you
> >> better do what this console says, it is a very clever one =)
> >> If it says that it needs a proxy, it is very likely it needs one, just
> >> add the one you use, localhost:8080 or something like that, you can
> >> start playing with that and the FB console will tell you what to do
> >> after each step. Trust in this console, it's our friend =)
> >> Cheers,
> >> Gery
> >> si NO es necesario.
> >> Date: Wed, 4 Jul 2012 11:33:24 +0100
> >> Thanks Gery...
> >> I think that now i'm using ol firebug because i got alerts:
> >> proxyNeeded Object { url="http://localhost:8080/geoserver/testes/wfs"}
> >> This means i nedd proxy despite i'm using only local data?
> >> Thanks
> >> Em 04-07-2012 11:16, Gery . escreveu:
> >> Hola Pedro,
> >> I don't know if this helps, but you're using firebug as add-on of
> >> firefox or the one it comes with OpenLayers? I think you're using the
> >> first one. I've had better results (generally spoken) with the second
> >> one, just add the path of the javascript to your html <link>, I don't
> >> remember well the path but if I'm not wrong is
> >> /openlayers/lib/openlayers/Firebug.js, you can google it also. That js
> >> script is really useful, it tells in detail where the error is (ie.
> >> which js script and which line), at least in my case. Also, even though
> >> I don't work with geoserver or bing, I think you have to specify the
> >> projection in bing, but not sure. Sometimes I found that projection
> >> stuff is the one that *ucks everything.
> >> Hope this helps,
> >> Gery
> >> si NO es necesario.
> >> Date: Wed, 4 Jul 2012 11:06:36 +0100
> >> To: ramotswa at gmail.com<mailto:ramotswa at gmail.com>;
> >> Also no erros on console...
> >> Anybody have an ideia?
> >> all the code here:
> >> http://pastebin.com/mRnDC3UG
> >> Em 04-07-2012 10:58, Toby Reinicke escreveu:
> >> Umm, yes, theoretically, although I'm slightly confused why there is
> >> only one tab and hasn't got a response one. Your syntax looks fine,
> >> although others might be able to confirm that. As for proxy, as you say
> >> you should be fine, and if it wasn't you'd get some cross domain errors
> >> in your console..
> >> Sorry I can't help more.
> >> Toby
> >> On 4 Jul 2012, at 10:27, Pedro Costa
> >> <pedrocostaarma at sapo.pt<mailto:pedrocostaarma at sapo.pt>> wrote:
> >> Hi Tobias,
> >> This(image attached)?
> >> Em 04-07-2012 10:21, Tobias Reinicke escreveu:
> >> If you expand that "options.wfs" in the firebug console, what does the
> >> "response" tab have in it?
> >> On 4 July 2012 10:09, Pedro Costa
> >> I forgot image....
> >> -------- Mensagem Original --------
> >> Assunto: my vector data don't show up - wfs
> >> Data: Wed, 04 Jul 2012 09:56:54 +0100
> >> De: Pedro Costa <pedrocostaarma at sapo.pt><mailto:pedrocostaarma at sapo.pt>
> >> Para:
> >> Hi,
> >> I'm trying to add vector data to my map from geoserver but data don't
> >> show up.
> >> I tried like that:
> >> var wfs = new OpenLayers.Layer.Vector("Equipamentos_WFS", {
> >> strategies: [new OpenLayers.Strategy.BBOX()],
> >> protocol: new OpenLayers.Protocol.WFS({
> >> url: "http://localhost:8080/geoserver/testes/wfs"<http://localhost:8080/geoserver/testes/wfs>,
> >> featurePrefix:"testes",
> >> featureType: "testes:equipamentos",
> >> featureNS: "namespacetestes.pt<http://namespacetestes.pt>",
> >> srsName: "EPSG:900913",
> >> geometryName: "the_geom",
> >> version: "1.0.0"
> >> map.addLayer(wfs);
> >> I'm using only data from localhost (my computer) so i don't need proxy
> >> right?
> >> Using firebug I can see that the request is made, but returns nothing
> >> (image attached).
> >> Can anybody help me?
> >> Thanks
> >> Users mailing list
> >> Users at lists.osgeo.org<mailto:Users at lists.osgeo.org>
> >> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> >> <request.png>
> >> _______________________________________________ Users mailing list
