[OpenLayers-Users] Component returned failure code: 0x8000ffff (NS_ERROR_UNEXPECTED) [nsIDOMHTMLDocument.implementation]
Aaron E-J
azintirea at gmail.com
Wed Jul 11 12:41:17 PDT 2012
The OpenLayers.debug.js version seems to work for the 2.12 version, not
sure what the issue is with the other versions.
Aaron E-J
http://otherrealm.org
http://aaronej.blogspot.com
Vision without action is a daydream,
Action without vision is a nightmare,
One needs both to succeed.
On Wed, Jul 11, 2012 at 2:52 PM, Aaron E-J <azintirea at gmail.com> wrote:
> Well, now it's happening using: http://openlayers.org/dev/OpenLayers.jsas well. Will try an earlier version and see if that fixes it
> Aaron E-J
> On Wed, Jul 11, 2012 at 12:28 PM, Aaron E-J <azintirea at gmail.com> wrote:
>> This only seems to be for the local copy I have (lib/OpenLayers.js),
>> using http://openlayers.org/dev/OpenLayers.js works find
>> Aaron E-J
>> On Wed, Jul 11, 2012 at 12:19 PM, Aaron E-J <azintirea at gmail.com> wrote:
>>> I started getting a strange message on occasion (usually happens but
>>> occasionally does not) that I'm not really sure how to fix it. There are
>>> two forms of the same message in firebug, both seem to be about the same
>>> thing:
>>> Uncaught exception: [Exception... "Component returned failure code:
>>> 0x8000ffff (NS_ERROR_UNEXPECTED) [nsIDOMHTMLDocument.implementation]"
>>> nsresult: "0x8000ffff (NS_ERROR_UNEXPECTED)" location: "JS frame ::
>>> http://localhost/phpEx/lib/OpenLayers/Renderer/SVG.js :: <TOP_LEVEL> ::
>>> line 77" data: no]
>>> error source line:
>>> return (document.implementation &&
>>> The function that this appears to be effecting:
>>> * APIMethod: supported
>>> * Returns:
>>> * {Boolean} Whether or not the browser supports the SVG renderer
>>> supported: function() {
>>> var svgFeature = "http://www.w3.org/TR/SVG11/feature#";
>>> (document.implementation.hasFeature("org.w3c.svg", "1.0") ||
>>> document.implementation.hasFeature(svgFeature + "SVG",
>>> "1.1") ||
>>> "BasicStructure", "1.1") ));
>>> I'm using the latest Firefox release (13.0.1) and it should handle SVG
>>> no problem… My guess is this is a bug related to OpenLayers v2.12. Does
>>> anyone know whether this is, in fact, a bug and whether it is being dealt
>>> with? Thanks.
>>> Aaron E-J
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120711/97b20246/attachment.html>
